Thread: Screenlogic missing temperature history
    Sep 2012
    Cypress, TX
    63
    I have a recently installed Pentair screenlogic interface which has been working fine for the past few weeks but all of a sudden is not loading any of the temp history. I just get a spinning circle (see screenshot).
    From searching the web it looks like some sort of query glitch but I am unable to identify if there is an easy way to fix / reset this. Everything else with screenlogic seems to be working fine.
    Has anyone encountered this and if so is there a way to fix it?
    Many thanks
    18,000 Gallon IG, Pebble Sheen, Quartzite coping
    Pentair 420 Cartridge Filter, 2HP Silencer, 400,000 BTU Heater, Platinum Legend Cleaner
    2x IntelliFlo VS pumps - Screenlogic Interface - Stenner 45MPHP10 15 Gal Bleach Injection
    TF100 + PoolCalculator + This Site!
    Sep 2012
    Cypress, TX
    63
    Re: Screenlogic missing temperature history
    For anyone who may encounter this issue, it is resolved by updating / re-loading the protocol adapter.
    http://www.pentairpool.com/pool-owner/r ... ns-new.htm
    Feb 2012
    San Jose, CA
    76
    How much temperature data do our systems store? It seems to be between 5-7 days, but I'm guessing it might be longer?
    Also, can you export this data as a csv?
    Filled 5/1/2013! 36k gallon 20x40 IG with 7x7 spa, FinestFinish, AquaMatic cover, All Pentair: Clean&Clear 520 sqft cartridge filter, Intelliflow 4x160 variable speed pump, 2 HP whisper flow spa jet pump, 400k BTU MasterTemp heater, Letro Platinum pool cleaner, Rainbow 320 chlorine feeder, Pac Fab Bermuda skimmer
    More details: pics-new-pb-20x40-ig-gunite-7x7-spa-7x7-shamu-shelf-t54952.html
