Thread: Auto cover has separated from wall
    May 2012
    Elko, MN
    13
    I noticed a few weeks ago my water level in the pool was super low. Hard to tell with 10 inches of snow outside. The weight of the snow/ice has pulled the track from the wall. Pretty sure this is very bad. Anything I can do till things start to melt? I have tried to shovel some of the snow off but I can't reach very far in.
    27000 gallon in-ground with an Aqualink RS, Jandy Plus 1 hp pump, Aquapure 1400 swg, Jandy CL460 cartridge filter, Jandy LX gas heater, Polaris 280 cleaner with a pb4-60Q booster pump, and an automatic pool cover.
    Re: Auto cover has separated from wall
    Yes, bad No, there really isn't much you can do until all of the snow melts.
    May 2012
    Elko, MN
    13
    With my water level so low and only one side of the cover has pulled off the track, would it help to add water to the pool? It looks like the shallow end is half full, so i'm guessing the water level is 2-3 feet low.
    That depends on why the water level is that low. If it was winterized that low there may be a reason why that was done that shouldn't be changed until freezing weather is over. If it drained down to there on it's own there is probably a leak and it will drain down to there again if you fill it up.
    May 2012
    Elko, MN
    13
    It must be a leak, the company that closed it said the cover sits on the water so the level needs to stay at the bottom of the skimmers. With one of the side walls still attached to the cover, would I be saving anything by trying to keep the water level up or would I be just wasting water?
    If there is a leak, constantly adding water is not only expensive, but it is likely to wash out more soil behind the leak, making things more difficult to repair.
    I suppose the question is, does the cover look like it is going to get worse if just left alone? If it has already done whatever damage it is going to do, then leaving it alone is your best bet. But if it is tearing off further and further each day you want to do something to stabilize it.
