Thread: Chlorinator not working showing low salt
    Hi
    I have an autchlor ac25t chlorinator that shows low salt and as a result the chlorine output is at0%
    Cell is clean and water flow is good. Salt has been tested and is good at 5000ppm
    What can I do to fix this issue?
    38,275
    Re: Chlorinator not working showing low salt
    Welcome to TFP!
    How old is the cell? One of the signs of the cell reaching the end of its life is low salt readings.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jul 2007
    Brisbane, Australia
    874
    it'd be either the cell (most likely if the unit is older than 5 years) or a control board
    if you are in Australia the best course of action would probably be to ring AIS on 07 3396 5222 and speak to their technical department
    if you are in Brisbane then you can even bring it to them and they can test it while you wait.
    how old is the unit?
    Thanks the unit is about 7 years old. Will give ais a call
    4knights's Avatar
    NE Kansas
    419
    Is your SCG affected by water temp? Mine doesn't work below 59 degrees water temp.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jul 2007
    Brisbane, Australia
    874
    nah autochlor's don't turn off, they will produce as long as they can pump out enough voltage to keep the amps up
    also the summer just finished here so the water should still be warm enough
