Results 1 to 8 of 8
Thread: Need pool equipment suggestions for pump & cartridge filters
    We bought a house with an in ground pool and want to upgrade some of the equipment. As new pool owners I'd like to get your advice on dual speed pump recommendations, as well as, cartridge filter suggestions - what model and size to buy? Prefer either a Hayward or Pentair. Thanks!
    33k IG plaster
    Advantage pool pump 1.5 hp
    Compupool cpsc36
    Hayward / Leslie superclear CF 150sq/ft
    TF-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Need pool equipment suggestions for pump & cartridge fil
    Welcome to tfp, Ahchoo
    Does the current equipment work?
    Do you have any water features such as spa jets, waterfalls, etc? Any details you can give us of your plumbing will help with pump selection.
    For the filter, your pool is big, so your filter should be too. For your 36000 gallon pool (are you sure of the size?) we would recommend a minimum of 534 sq. ft. cartridge filter.
    Practically any two speed 1 HP pump will do well. Personally, I'm partial to the WhisperFlo line. The 1 HP WhisperFlo is larger than the average 1 HP pump, which would be a good match to your larger than average pool.
    For the filter I suggest getting a nice large filter, much larger than what you have now. Larger filters are more efficient and can go longer between cleanings. Sand, cartridge, or DE is more of a personal preference than something I can recommend to you.
    Mar 2010
    Spring, TX
    1,082
    I have a Hayward swimclear cartridge filter. It seems to do a good job and has been installed for about a year and the gauge has never moved. Granted it is about 1-2 sizes bigger than what I need.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by mynewpool
    For cartridge filters, you really can't be too big, with that said, that would be a good choice for the ops pool, as would the other brands above 500 sq. ft. if the op wants to stay with a cartridge.
    I am curious how Ahchoo's current filter has been working.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Go with a 1hp 2 speed pump, and the largest cartridge filter you can afford, saves on cleaning. Not that it's hard, just a little time consuming. I have a CC100 on a 17K pool. I've got 2 cartridges that I get to swap in and out.
    No additional spa or water feature. All the equipment still work. The pump is making a high pitch noise. From what I been reading, the CF is too small. I want to get a efficient pump and a right size CF.
    33k IG plaster
    Compupool cpsc36
    TF-100
    Quote Originally Posted by linen
    I clean the filter every 2-3 weeks. It get dirty fast.
    33k IG plaster
    Compupool cpsc36
    TF-100
