Thread: Actuators for in floor cleaning systems
    Oct 2012
    Central Ohio
    180
    Just curious.Why doesn't someone make an infloor cleaning system that uses actuated valves.If you had one of those systems that uses 4 zones you could use 2 3-way valves and 1or 2 actuated shutoff valves (depending if the system had it's own pump) to turn your zones on and off via something like an Intermatic timer.I may be off my rocker but those valves and actuators don't seem to have very many problems. Or maybe a system that uses a manifold with something like irrigation solenoids to operate zones,infinitely expandable.I like the solenoid idea better.
    Thoughts?
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Re: Actuators for in floor cleaning systems
    That would work fairly well, but anything involving solenoids or actuators is going to be more expensive and less reliable than a standard cleaning system zone valve.
    Oct 2012
    Central Ohio
    180
    I see your point about price.I guess I should ask ,on average how long does an infloor cleaning systems control valve last before it needs serviced or replaced ? I don't really know how much an infloor cleaning system costs,but lets say it costs $6000,whats another $500.You just spent $60,000 or more for an inground gunite pool.As for reliability I would tend to disagree,everything has it's pro and cons.Do you have an irrigation system,how often does it fail ? I mainly use the ASCO solenoid valves at work,very reliable but not cheap.If you had to rebuild/replace a solenoid (IRRIGATION SOLENOID) your only talking about $10-$20 to rebuild and $60-$100 to replace per solenoid.Of course KISS is often the best route.The old Intermatic mechanical timer is almost bulletproof,it's about as simple as it gets.It really is a testament of keeping things simple.
    Rob
    SWCG,Uni-bead liner
    Borates
