Thread: Pitting in my grout.
    Sep 2010
    Yorba Linda, CA
    5
    [attachment=1:1nws2epx]photo.JPG[/attachment:1nws2epx]FC: 3ppm
    PH: 7.2
    TA :90
    CYA: 100+
    CH:650
    CH from fosset water = 275
    I have an issue with the grouting on my coping brickwork pitting. As you can see in the pics. I have high CYA so for the last year I've been using 12% Liquid chlorine and Dry acid (to control high PH drift) and nothing else. I did a 50% drain last year, after I fired the pool guy recommended by the pool builder. The CYA was through the roof and still isn't where I would like it to be.
    Is the High CH causing the pitting? It only seem to be at the brickwork closest to the waterline. I have the same coping at the top of the bond beam (3+ feet above water) and it isn't affected with the pitting.
    Many thanks
    Sean (Southern CA)
    15000 Gals, Catridge, IG, plaster, intelliflo VS-3050
    38,295
    Re: Pitting in my grout.
    No high CH would not cause the pitting. I would think low CH and low pH may do it ... though there may be something else at work.
    Just a note that a FC of 3 ppm is WAY too low if your CYA is over 100 ppm. You should be maintaining the FC above 7 ppm to prevent algae problems. Of course this has nothing to do with your question though
    Will have to wait for someone who knows more than me to answer that question.
    With high CH levels it is nearly impossible for that to be chemical pitting. It looks to me like the grout was improperly installed in some way so that it wasn't as sound as it should have been.
    30,421
    +1 on that. I imagine that grout can be removed with very little effort.
    Sep 2010
    Yorba Linda, CA
    5
    Thanks for the replies.
    I think it probably is poor installation of the grout. I remember it was a custom color they had to mix on site. The probably got the consistency wrong.
    I'll start getting quotes for repair.
    Thanks
    Sean
