Thread: Intellibrite lights - no wall switch?
    techgirl's Avatar
    Vernon, BC Canada - Pool is in Maricopa AZ (currently a holiday place)
    75
    My pool builder says that the wall switch is an "option" with the intellibrite lights. I know the full pentair controller box is an option, but the material I read when we went with the intellibrite said that if you don't go with the controller you use a standard light switch to change the light shows.
    Now I have these brand new lights and no way to control them
    I can use the suntouch remote to turn them on and off, but can't cycle through all the shows etc.
    Any advice would be appreciated as we've just started up the pool today and I need to go meet with the pool builder tomorrow.
    Thanks!
    Inground 12500 gallon 96 foot perimeter, 24 by 24 pool (6 by 24 of which is a "wet deck" or tanning ledge), intellibrite in spa and pool, 2 pentair LED bubblers in tanning ledge, built in table in pool, spillover spa, pebble radiance, Pentair Mastertemp 400K BTU heater, Blue Square Q360 infloor cleaner, VS2050 pump, auto leveler, Pentair easytouch 4 with wireless controller, Pentair 420 filter, custom natural gas firepit with cobalt glass.
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Intellibrite lights - no wall switch?
    This is an optional add-on with Pentair lights and IMO one of the better ways of controlling lights in a standalone fashion.
    http://www.pentairpool.com/pool-pro/pro ... er-401.htm
    Otherwise most LEDs change to different modes by flipping the light switch several times. For example flipping it on/off 4 times may lock it into one shade of blue whereas flipping it on/off 7 times may do a light show.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    techgirl's Avatar
    75
    Thanks JoshU - we decided not to go with the controller at this time, but the pool builder didn't even install a light switch so we have no way to control the shows! Our suntouch remote turns them on and off, but that's it .
    38,301
    It should be very easy to add a light switch right next to the controller you have ... between it and the light.
    Edit: based on your other post, I clearly have no idea what I am taking about as I was picturing one light needing a switch.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    It is supposed to be possible to control the lights with the SunTouch by turning them on/off the correct number of times from the SunTouch. Adding a separate switch is easy enough if you prefer that.
