Thread: How long pump operation with New Pool
    May 2012
    Flower Mound, TX
    130
    PB recommended 8 hrs a day for pump operation. 1100 - 1900, 4 hrs on high speed then 4 hrs on low speed. New Pool built last Monday. Does that sound correct?
    John
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: How long pump operation with New Pool
    Bit long in my book. Especially this time of year.
    I run mine 2 hrs on high speed and 2 on low during the heat of the summer and seems to keep the pool clean enough for me. Plus my pool is bigger than yours but you may need to experiment some because every pool is different and some need more skimming time than others. But I would keep high speed to a minimum unless you really need it. Low speed of a 2 HP pump should give you pretty good skimming action so you shouldn't need much run time on high speed.
    Mark
    May 2012
    Flower Mound, TX
    130
    Quote Originally Posted by mas985
    Thanks Mark,
    I'm going to check out how many water features I can operate on low speed, high speed looks better. But I do understand the wear of the pump in high speed. Maybe he wanted me to operate 8 hrs of pump time and 4 hrs of cleaner time because being a new pool! I get my TF-100 test kit this Monday, I'll check out the chemicals and decide if I need to adjust pump run. Thank you
    John
