Results 1 to 10 of 10
Thread: 38000 gal - taylor k-2006 test kit 20 drops of r0006 still
    test water is yellow- can't get a ph reading? -- end of last year ph was great-had 15 " of rain -kept draining off excess-added 45lbs of baking soda-
    readings
    ta 100
    cya 40
    cal 250
    cl not readable
    38000 gal inground - 1.5 hp hayward superpump 300lb sandfilter-k-2006 test kit-diving board-slide-10' x 15' tiki bar-outdoor living room
    38,475
    Re: 38000 gal - taylor k-2006 test kit 20 drops of r0006 sti
    Is there a question in here
    Baking soda raises TA more than any affect on pH.
    Are you happy that your FC is zero? Or is that a sarcastic Whoot
    no sarcastic -just thought it was a cool icon-trying to get my ph up is the question
    38,475
    Here are detailed instructions:
    extended-test-kit-directions-t25081.html
    I have not used the acid demand test, so not sure what 20 drops means.
    Does your pH show at the bottom end? Usually the TA ends up very low as well, unlike your 100ppm.
    This shows the chems needed to raise the pH ... soda ash is your best bet:
    pool-school/recommended_pool_chemicals
    i thought cl lowered ph? i have been using baking soda to raise ph for the last 5 years - hmm been wrong for 5 years? lol at me if its true
    the test i was doing was base demand not acid demand...
    38,475
    What is CL ... we do not use that ... assuming you mean free chlorine (FC).
    What type of chlorine do you use? Some is very acid and lowers the pH (trichor / dichlor), some is neutral (cal-hypo / bleach).
    I have not used base demand either.
    Baking Soda does not raise pH very much. Using the bottom of the poolcalculator.com:
    6 lb of baking soda in your pool would raise the TA by 11ppm and the pH by 0.02
    6 lb of soda ash raises TA by 18ppm and pH by 0.55
    according to the pool calculator i will need 16 lbs to get to 7.5 assuming my ph is 7.0 -- can't believe it fell that far-i've had the pool 8 years and never had this problem before--weird--i will get some borax and see if it raises
    38,475
    borax adds borates which you do not want very high ... plus it acts as another buffer to pH and makes it harder to adjust TA and pH.
    I would stick with soda ash / washing soda for now.
    EDIT: Although in the quantities you are talking about, it will not raise the borates much, so either is fine.
    cool thanks for the heads up -i will try soda ash-
