Thread: Tf-100 Kit....... shelf life
    how long would you say all the cool stuff in the kit lasts, it has been kept in the laundry room. but i still have a great supply of all the tests, but since im not takeing care of the pool for a while, how long can this stuff sit.
    The TF Test Kit uses Taylor reagents. Taylor only rates their reagents for one year. However, stored in a cool dark place everything in the test kit should last at least two year and quite possibly longer.
    Apr 2008
    Hi Jason,
    My order for the TF-100 is plenty of back up reagents. Since my ambient temp here is high, will it help if I put in a refrigerator at 4 deg celcius ?
    35,000 GL pool. In Ground. Concrete with all white ceramic tiles. Outdoor but shaded.
    Approx 36 ft by 15 feet. 2HP Hayward Super Pump, Hayward Sand Filter with Zelbrite ( Zeolite ), Hayward Cartridge Filter, Aquamatic Silver+Copper Ionizer ( suspended use since Oct 2008 ), Prozone Ozonator, 2 gram/hr, Analog Flowmeter on pipe
    Back Up Pump & Filter on trolley, Pentair 1.5HP + Pentair Cartridge Filter, Slime Bag 1 micron Jumbo Size, downstream of Cartridge
    It's not just temperature but the chlorine test reagents are ruined by light, moisture (for the DPD powder), and oxygen. All the other reagents in the kit should last at least 2 years or more if not stored under extreme conditions. the DPD powder and FAS titrant are the ones with the short shelf life.
