Thread: Test high Chlorine levels
    mnittler's Avatar
    Sep 2012
    South Texas
    58
    How do you test for Chlorine over 5.0 which is the maximum of my test kits?
    I have several different test kits but none of them goes over 5.0 Chlorine
    Hach CN-39WR Hardness, Iron, pH, & Chlorine (I already had this test kit to test water)
    Taylor K-1004 Pool & Spa Test Kit (Furnished by PB)
    Taylor K-1720 Cyanuric Acid Test
    Taylor K-1766 Salt Water Test
    Taylor K-1106 Phosphate Test
    TF-100 Test kit with XL option (On order from TFTestKits.net) I should have ordered this one first instead of last.
    21,500 gal sport pool, 8' spa, beach, 400k btu LP heater, Pentair IC60 SWG & #300 Tablet Feeder, 60 sqft DE filter, Paramount in-floor PoolValet 3 cleaners, Debris Canister, Polaris 360, Pentair VFD 3hp pump, IntelliPh, Geysers & Turbo Twister Slide w/1 hp pump, Color LED Pool & Spa lights, E-Z Touch8 control system, Wireless controller. Test Kits:TF-100, Taylor K-1004, CYA K-1720, Phosphate K-1106, Salt Water K-1766, Hach CN-39WR.
    38,267
    Re: Test high Chlorine levels
    You need the FAS-DPD chlorine test. This is really the key test to taking control of your pool.
    If you already have Taylor tests for pH, TA, CH and CYA, you can order it separately here:
    http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    Or get the TF100 from the same place.
    EDIT: looks like you already ordered the TF100 ... so you will be good to go!!!
