Thread: Can you have too big of a filter?
    May 2009
    Mn
    198
    We are looking to move to a cartridge filter. We've been educated here that bigger is better. Could we get a filter that is simply too big for our pump to move water through? We contacted sta-rite (we have a 2speed 1hp dynamo pump) and they suggested a Plm 125 sq foot filter. I've been told here that we should have 300 sq feet.
    My concern is that when the pump is on low (.12 hp) that it won't be able to move water through the cartridge (plm 300).
    Also we only swim 3 months out of the year so it'd be nice to only have to clean the cartridge at close down.
    Our pump pad is about 10 feet from the pool, and we have a heater...we pump 24hrs a day due to the heater.
    Thanks! Can't wait to get swimming again!
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Can you have too big of a filter?
    For a cartridge filter, you should have less resistance with a larger filter making the pump's job easier, so the only negative would be the cost of the filter and replacement cartridges.
    Short answer, no a cartridge filter can't be too large. Larger filters go longer between cleanings and they are more efficient. However, they are also more expensive and take up more space. We recommend getting the largest filter you can afford and have space for.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    All common pool filters are more efficient when they are larger. They take longer to get dirty, filter more effectively, and reduce flow less than their smaller counterparts. They are however more expensive both in upfront costs and ongoing costs related to filter media.
    May 2009
    Mn
    198
    Thank you for the replies. Space is not an issue and the pain of having to clean a smaller filter mid season, justifies the $ for the bigger filter.
    Jul 2012
    Chicago, IL
    356
    MN Pooldreamer, I notice you have the same pump that I am about to buy so wondering if you would mind sharing your opinion or experience with it? How long have you had it?
    As for filters, cleaning it as you are closing rather than during season is very nice!
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
