Results 1 to 10 of 10
Thread: Ph Rise Question
    Ph Rise Question
    I am curious what kind of rise I can expect from using an aerator attached to a return. I am getting a good "fountain effect" through a 2" pvc pipe (capped with about 12 drilled holes). I installed last Saturday AM, but I seem to be stuck at 7.2 for the last 3 days. Pump run time is 12 hrs/day at present.
    All of my other numbers are within normal parameters. Water temp is < 50 degrees F.
    Any discussion/input is appreciated.
    Best,
    Sciz
    Completed March 1, 2013. 12,500 gallon IG Lagoon Style w/swimout, walk-in steps, 15' x 30' x 3' - 5', Gunite, Wet Edge Technologies, Pebble Sheen - Northshore Tahoe, 2" Tennessee Fieldstone Coping, Belgard Country Blend Pavers, 1.5 HP Superflo, 19" Tagelus Filter, IC-20 SWCG.
    Apr 2012
    SW Ohio
    456
    Re: Ph Rise Question
    What is your t/a reading?
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    How are u testing and can you post a full set of test result please
    Sure thing.
    Results as of this morning:
    FC - 4.5
    CC - 0
    ph - 7.2
    TA - 90
    CH - 240
    CYA - 40
    Best,
    Sciz
    Apr 2012
    SW Ohio
    456
    It could be lower than 7.2 which would give the effect that it is not moving
    Not cool! Any way to hack the test to re-confirm results? Maybe add a little bacon fat to it or something?
    22,543
    I think I'd just be patient for a couple more days with the fountain running and see what happens.
    If it's 7.2 why are you wanting to raise it so quickly?
    Hi bama - not necessarily trying to raise it quickly - it is my first effort to raise ph by aerating - wasn't sure what to expect with the duration. Well - it looks cool anyways and makes a pleasing sound so....
    I should have mentioned we got an inch of rain 2 days ago - wonder if that might have had an effect.
    I'll let it go and just make sure I'm testing daily. Thanks all.
    Best,
    Sciz
    s
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Quote Originally Posted by Sciz Milson
    Rain is generally a PH neutral event. While usually acidic, the rain event itself aerates the water and offsets.
    Your signature indicates that you have an SWG. However, since the plaster is less than 30 days old, that should not be operational, yet. If you are using trichlor until the SWG is ready, then that will lower the pH and offset some of the pH rise from aeration.
    If you are using liquid chlorine, then the low pH with fresh plaster is unusual.
    If you are using trichlor, then you could raise the TA about 10 to 20 ppm to get a rise in the pH.
    Support the site
