Thread: Surface Returns and In-Floor Cleaning System
    What's the consensus of having surface returns with an in-floor cleaning system? Are they necessary? Details: Paramount PV3 in-floor system w/17 heads, Diving Pool depth is 3.5-8. Surface area 514 sf, 102 perimeter, 38x16 freeform. Pump is VS3050. Builder says surface returns are not necessary. I'm not convinced that the in-floor will be enough to circulate surface water especially on the deep end. Seems like a small area to skimp on. Granted, one half of the pool wall is exposed. Due to slope of the lot, one half of the pool is exposed from 0-26" so I'm not sure of the logistics of putting in surface returns. Any advice is appreciated.
    JimboAZ's Avatar
    Oct 2012
    Maricopa, AZ
    103
    Re: Surface Returns and In-Floor Cleaning System
    Check out my old post here --> do-we-need-returns-t55061.html
    --22k gallon pool/spa, IG, pebble w/ glass beads/abalone, all tile spa w/ stacked stone and spillway, 30 sf waterfall, 3 telescopic fountains, EZ Touch 8
    --Pentair VS3050, Whisperflo waterfall pump, Clean & Clear 520 cartridge filter, Intellibrite 5G LED lights, Ozone, Q360 in-floor cleaning, 400k btu heater
    --100 perim ft pool, 25 perim ft spa, Depth 3.5' to 7', 405 sq ft travertine decking, TF100 test kit
    --Time Lapse Video of our Pool Build ---- Our Pool Build Thread
    Quote Originally Posted by JimboAZ
    Thanks for the reply and the link, but there wasn't anu definitive information in that thread; just debate about whether an in-floor was better than a robot. I do want the surface returns but am getting push back from PB. Sounds like maybe we have the same PB?
    38,371
    I vote get them. Offers an alternative to maintain circulation if there is a problem with the floor system.
    Edit to clarify, the wall returns should be separate from the floor system with a 3 way valve to select them ... not a part of the system through the manifold.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    JimboAZ's Avatar
    Oct 2012
    Maricopa, AZ
    103
    Quote Originally Posted by AZHeat
    Yeah, not much useful except that it seems like a good idea. Our PB (Presidential) didn't have a problem adding the returns as long as we paid for them. It was pretty cheap so we went for it. They would've added them to the in floor cleaning manifold if there was space (for free) but as jblizzle said it's better to have them independent. We also added a dedicated suction line.
    Nov 2011
    Moberly,MO
    1,010
    I would pass on the paramount and just do a robot. Have sold and installed paramount and wish I wouldn't of, not that great of a system. Not sure why 17 heads that might be itsonly saving grace enough heads to make it work
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
