Results 1 to 16 of 16
Thread: 20 yr old pool, brand new pool deck / patio.
    Mar 2013
    North Canton, Ohio
    50
    Hello everyone and thank you for this unbelievable site, my family and I moved into our home on christmas day 2011 and were fortunate enough that it came with a beautiful 16x32 ig pool. Last summer was my first experience with a pool and I did pretty well, minus the one and only water incident (cloudy) the morning of a HUGE party (lucky huh?).
    I just found this site about a month or two ago and have been on pool overload ever since, what I have not stumbled across or maybe can't find because of my lack of knowledge is this:
    I will be tearing up 800 sq ft of existing patio that butts up to the 4' strip going around the pool, and also a complete equipment relocation. With that being said, what can I, what should I, or what do I make sure I take advantage of while the patio is torn out prior to the new stamped concrete patio being put in?
    I know you all need more information and pics but I will have to get that when I get home to make sure I am 100% correct on everything (I just had a bit of time at work right now to start this topic and this is all I can think about). I do have a sliding board, a retractable fountain that comes out of the bottom, 2 return jets, one skimmer, and what I believe is a port for a vacuum but the line is blocking that and the pipe is stubbed out of the ground by the pump but not hooked up to anything.
    "There are no bad days, just some better than others"
    18k, Ig Vinyl, 3/4 us motors, Hayward sand filter, quickpure3 ozone generator
    Feb 2008
    Denton, TX
    5,061
    Re: 20 yr old pool, brand new pool deck / patio.
    Welcome to TFP! Sounds like an interesting project that you have planned. I'm curious to know your reasoning behind relocating the equipment pad.
    Mar 2013
    North Canton, Ohio
    50
    Thank you for your reply sir, I will post pics so it is much easier to understand, but the bottom line is that the new walkway will be layed right on top of where the equipment sits now, and that is because where the walkway is now is where my garage / outdoor kitchen / bar is going. So with that all being said while my ditch is open to the new location I was wondering if I should put a couple extra return pipes in for future deck jets or waterfall or whatever else you pro's do.
    Shoot I almost forgot I also emptied my sand filter to replace the sand is there anything special to look for in sand or just get pool or filter sand? And how much? because I cant read any of the labels on the filter
    Mar 2013
    North Canton, Ohio
    50
    I doesn't look like I hit a good topic or maybe it makes no sense, but here's a link to pics before:
    https://plus.google.com/photos/10617370 ... I_qmPvskgE
    22,550
    Unless you can terminate the unused pipes somewhere easy to later find, there's not much use in installing them. Now if you have a specific location for them the by all means go ahead and have them ran.
    As for the filter, You need #20 filter sand. We'll have to know the model to know how much it takes. If you can give us some measurements we may be able to figure it out. It looks like a Hayward S-200 or S-240 (more like a S-240). If it is the 240 it takes 300# of sand. The S-200 takes 200#. Measure the inside diameter at the seam to make sure which it is.
    Mar 2013
    North Canton, Ohio
    50
    Thank you so much sir for your reply, I believe it is a s-200 I read that somewhere on it when I was cleaning it. I dont want anyone to think that I'm nutty or anything but I want to get everything in the ditch as possible because unfortunately there will be a garage on top of the ditch hopefully next year (and it will be too late then). I was thinking about deck jets or a waterfall or something and yes was just going to leave it stubbed up right under the surface of the ground between the pool deck and the garage.
    Any thoughts on deck jets? I would have to do that now before the patio gets poured.
    Also while I have you here, I now have 1 1/2" black pily pipe and after my TFP education, I will be converting that to 2" sch 40 to go the extra 24' to the new pool pad. It is at that end I have questions on my 8 - 2" stubs coming out of the ground I was going to use ball valves but after looking at hundreds of pad pics and reading here im now leaning toward 1 ball valve (waste line), 3 2 way jandy's on the suction and 4 - 2 way's on the returns. Overkill? Should I use 2 - 3 ways and 1- 2 way instead?
    22,550
    If it's an S-200 then you need 200# of #20 sand. Make sure it's pool filter sand.
    Since you have a real reason for wanting to run extra pipes (future building) I don't blame you for doing it now. Changing from poly pipe to PVC is a great plan.
    I wouldn't put a valve at all on the waste line unless there's some special reason to.
    I prefer 2-way valves over 3-way valves but that's strictly a presonal preference and either will work just fine for you. The rational behind using 3-way valves is you save a valve and the chance of closing off both flow paths is a little less with a 3-way than with (2)2-ways.
    Mar 2013
    North Canton, Ohio
    50
    Is there any reason I would ever need to adjust the flow or shut off my return jets? Or just put one on cause it will look better? Haha
    Then my next question would babe where is the best place to buy 6 - 2 way jandy valves? And I will someday upgrade all of my equupment to something? And would like it alI to go well togetheris jandy ok to stay with or look at the other two also?
    Thank you very much sir for your time, you'll be sure to get put on the christmas list!
    22,550
    I doubt that you'd ever need to adjust the flow out the return jets with the valves. The best way to change the flow out of the jets is to change the eyeballs.
    You may need to adjust the flow from the skimmer and/or main drain but you can do that with 2-way valves. If I were going to install a 3-way valve, the suction side is where I would install one.
    Mar 2013
    North Canton, Ohio
    50
    I am gonna just order 6 - 2 way Jandy valves and call it a day, 3 on the return side for water features (slide, fountain, and deck jets) and 3 on suction side (main drain, skimmer, and cleaner). Thanks again sir
    Mar 2013
    North Canton, Ohio
    50
    ok everyone with the Pad Relocation I have the oppurtunity to make my cleaner port suction or pressure, what is the vote on what to do? I really would like your opinions and need to know because I will have to order another Jandy valve.
    Mar 2013
    North Canton, Ohio
    50
    Can someone please give me their opinion on the cleaner port in the side of my pool, I really don't know which I would benefit from most, making it a suction side port or a pressure side (without adding a booster pump right now)
    22,550
    It's hard to give a recommendation because either will work fine. It really depends on your preference. I would go with a suction cleaner and not have to deal with a booster pump, but they also make boosterless pressure side vacuums. It'd be nice if you could rig it so you could switch it from one to the other.
    Mar 2013
    North Canton, Ohio
    50
    My Pool guy (who I actually trust) said it's 50/50, chevy/ford kind of arguement, he said making it pressure I can hook some kind of gizmo uo to it and make another water feature type thing. Already having the fountain thats not really necessary, but **** there are alot of things not necessary in life but I like making it both, I have to sit on that one for a minute so I can make it dummy proof
    Mar 2013
    North Canton, Ohio
    50
    And thanks Dave for all your help, sorry if I'm full of stupid questions.
    Mar 2013
    North Canton, Ohio
    50
