Thread: Pressure gauge on old Sta Rite filter
    Feb 2013
    Melbourne, Australia
    102
    The filter our pool is a Sta Rite sand filter, model number is w-9463005-1, and the pressure gauge is stuck on 25. I'm guessing this filter is really old since I can't find any information on it. Are gauges generic fit and can I just unscrew this one and replace it with a new one?
    Also, given it is likely very old, I've read about replacing sand. When the pool is balanced, it keeps it really clean but I notice that if I vacuum to the filter, then backwash, rinse and return to filter, the pool goes very cloudy. I backwash until the water though the glass sight bottle is clear then rinse for 10-20 seconds, then return to filter, but it will guarantee cloud the pool every time. Is any of this an indication that sand needs replacing, or should I be doing something else?
    41k litre (11k gal) shotcrete in ground pool, Hayward super 2, Davey Monarch 28, zodiac SWCG
    - undergoing a transformation!
    2nd season Pool Owner. TF-100 testing
    Melbourne, Australia.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pressure gauge on old Sta Rite filter
    Filters gauges here in the us are pretty standard at 1/4" npt but I am not sure about down under. I would guess they are.
    Are you shutting off the pump before changing filter positions? Make sure you are.
    You may need to rinse a little longer to remove the cloudiness.
    Another possibility is your spider gasket could be worn out allowing stuff to bypass the filter on restart.
    30,403
    I completely agree. I have to rinse for at least a minute to resettle my sand bed and avoid a cloudy plume of dirty water back to the pool
    Re: Pressure gauge on old Sta Rite filter, mine reads the sa
    I have exactly the same vintage Sta-Rite model 9463005-1 high rate sand filter and the pressure gauge on the threaded cap also reads 25psig on a continuous basis.
    I agree that I have not been able to find any mfr information on this old sand filter (late 1970s or early 1980s). Were they bought by Pentair?
    This 30"diameter filter has a screw cap on top like a Triton with a Hayward Vari-Flo on the side pipes. I would like to screw open the cap but before I attempt it (no hex key) I would like to have a replacement O-ring and cap on hand.
    Do any of you pool experts know specifically which web site can tell me about this filter for spare parts?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Pentair owns Sta-Rite. You may want to contact Pentair customer service for help finding parts.
    Love TFP? Become a
    TFP Supporter!
