Thread: radiant sand filter question
    Apr 2012
    SW Ohio
    456
    i am thinking about buying a 16 inch or 19 inch radiant sand filter for my intex 18x52 pool i have the 14 inch intex sand filter on it now with a 1/2 hp hayward pump which puts out 40 gpm, will my pump be better suited for the 16 or 19 inch radiant sand filter?. i know this filter will probably be overkill on my intex but i plan on going to a larger pool in the next couple of years, i have never heard of the brand and can't find any reviews on them to decide. i would lie to go with the 19 inch but i want to make sure my pump is up for the task........Mike
    http://www.poolsupplies.com/shop/equipm ... nd-filters
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: radiant sand filter question
    Is you current filter not working? That pump that comes with the 14 is pretty small. I am not sure it would properly backwash the 19" filter adequately.
    If you are planning on upgrading in the future, I would pick a pump and filter that meets the future needs and not compromise the filter to match your current pump. If you are like me and do not know your future, then I would wait unless the current setup is broken.
