Thread: Polaris 280 Universal Wall Adapter (UWA) Stuck
    So my wall adapters pegs broke so I need to replace it. I figure this would be an easy fix, but apparently not. Seems the previous owner used some kind of silicon on the UWA threads when installing. The unit is stuck and after trying with channel locks it broke so only the threaded part is still in the wall.
    I am curious of what you folks think as a possible way to get it out. All I can think at this point is to hacksaw carefully and hope I can take it out in pieces - my concern is the silicon they used and that its going to be stuck very bad.
    thoughts?
    25K gal plaster IG pool/spa - Aqua Pure SWG - Jandy RS8 with OneTouch and iAqualink - 1.5HP Jandy Variable Speed ePump - Pentair 3 HP Spa Jet - Polaris 280 with booster - Pentair Cartridge Filter - 400K BTU MiniMax Heater
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: Polaris 280 Universal Wall Adapter (UWA) Stuck
    I think there's a flange on the back of the UWF with a couple of slots in it. I stuck my channel locks, handle first, into those slots and was able to unscrew mine.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Funny after posting I went this route. I put in a pair of pliers as it was wide enough. I then used the channel locks on the pliers to twist it and it finally broke free. See pics.
    [attachment=2:2r7632ri]ImageUploadedByTapatalk1363035114.379915.jpg[/attachment:2r7632ri]
    [attachment=1:2r7632ri]ImageUploadedByTapatalk1363035129.712678.jpg[/attachment:2r7632ri]
    [attachment=0:2r7632ri]ImageUploadedByTapatalk1363035164.312489.jpg[/attachment:2r7632ri]
