Results 1 to 8 of 8
Thread: Testing chlorine at higher ppm than the test kit is capable?
    May 2008
    South Central PA
    20
    Right now I have a HTH test kit (not in the budget to get a Taylor kit, as much as I would like one)
    Is there a way I can test for higher chlorine amounts through diluting the sample?
    HTH says use 5 drops of the reagent
    one otherthing do these reagents have a shelflife?
    Thanks for any help
    Mike
    13,500 gallon AGP, 1-1/2hp pump 150# sand filter
    Round Rock, TX
    529
    If you dilute the pool water sample with distilled water you will double the testing range. At the same time you double the error, but at least you can get an idea as to your chlorine level.
    I've always heard that you should replace your reagents yearly.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Yes you can. You lose some accuracy, but when you are shocking it's not a huge deal. Mix the pool water sample with three parts distilled water, and then you test the mixture. Multiply the result by four.
    The reagents have a shelf-life, but if they are stored at reasonable temperatures out of the light, they last a long while. I found a test kit with an expiration date of 1996 last summer, and the results were indistinguishable from my TF-100. The reagents had been in a box in the basement since 1998.
    NJ
    291
    Why not just put one drop in and multiply by 5 or put two drops in and multiply by 2.5 to estimate your reading.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    Varying the number of drops changes the visibility of the color but it doesn't change which color it matches on the color standard. Or to put it another way, fewer drops makes it more difficult to read, but gives the same answer as the usual number of drops.
    NJ
    291
    WOW, so you mean you are not doing a titration and the number of drops really don't matter?
    I just realized that what I said might not be accurate so I deleted it..
    19,000 vinyl pool, solar heat, .75 hp tristar, 48 sq ft de filter
    Quote Originally Posted by kirbinster
    The test under discussion isn't a titration, it is matching against a color standard. When doing a titration you count drops till the color changes. When matching against a color standard you add indicator and then compare the color of the water to the color standard. For a titration the number of drops matters a great deal. For comparing to a color standard the number of drops doesn't really matter, it is just a convenient number to make the color easy to see.
