Thread: Bulges in fiberglass pool wall
    Oct 2012
    209
    Hey all,
    I have a potential project coming up and I have a question for the pool builders out there. This project is a renovation job that involves an old concrete bottom/fiberglass walled pool. Due to the pool being left drained in combination with a gap between the concrete decking and coping, the fiberglass pool wall has bulges in a few locations. My plan is this, remove the old concrete decking in those places that have bulges, dig out the old backfill, support the pool walls, re-fill and replace old backfill with bluestone. Then put down new concrete and seal the space between the deck and coping with foam rod and expansion joint sealer. My question is (especially with the space between decking and coping being in more places than the wall has bulged), should I replace the backfill around the whole pool instead of just the spots where the wall has bulged? See attached pictures.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Nov 2011
    Moberly,MO
    1,010
    Re: Bulges in fiberglass pool wall
    Good plan. Suggest trying to put some sort of anchor for deck to adhere to walls. I think as I backfilled I would be filling with water or maybe fill first then backfill.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
