Thread: Safe to get in Hot Tub (FC 14)
    Hello, I have an in ground pool with a SWG.
    We haven't used our spa or pool all winter. We were wanting to use the spa so I decided to test the water.
    The FC came back at 14 which shocked me, I'm assuming I'm running my SWG at too high of a %.
    Also tested my CYA at 20.
    My question is, is it safe to get in the hot tub with that FC level?
    Steve
    25,000 gal plaster IG
    DE Filter
    Jandy SWG, 2.0hp Jandy Stealth pump
    DFW Area
    Re: Safe to get in Hot Tub (FC 14)
    Probably, but I don't recommend it. As a general rule, swimming/soaking is fine up to shock level for your CYA level. Shock level for CYA at 20 is 10, so you are a little too high.
    Thank you Jason. That's the conclusion I came too after seeing the CYA chart, just wanted to double check. The skin on my hands is stinging a bit just from working in the water a bit earlier.
    DE Filter
    DFW Area
