Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: New build in Metro St. Louis
    Feb 2013
    Metro St. Louis
    93
    We signed the contract with our PB last week. The first step is for me to demo our existing deck/landscaping. I finished that today!
    The PB is coming out this week to mark locations, with the hope of starting the build in about two weeks.
    Here are the specs from our contract:
    * Sterling Steel Shell, freeform, 21' x 35', 6' deep end
    * 1" clean rock backfill, drain line around/under pool to sump pit
    * 2 skimmers, individually valved at pump pad
    * 4 returns
    * In-pool wedding cake steps
    * Stamped colored concrete coping
    * 1,274 sq/ft colored concrete decking
    * Pentair Intellibrite 5g LED lights (x2)
    * Pentair Landscape LED lights
    * Pentiar IntelliFlo VS pump
    * Pentair 420 Cartridge filter
    * Pentair IC20 SWCG
    * Pentair EasyTouch 8 Controller
    * Umbrella sleeves (x5)
    * Plumbed for future pressure side cleaner from pump pad to pool
    * Gas line for future heater, and 4 gas Tiki Torches
    * LoopLoc Ultra Loc II cover with panels (tan)
    * Deck Jets valved at pump pad with electronic actuator (x3)
    * Raised Planter Bed with Rosetta Stone Belvidere and 2 Pentair bronze sheer decents, valved at pad with actuator
    * Black aluminum fencing around pool (54")
    * Pool filled with city water from garden hose
    * Will be buying TF100 test kit from forum sponsor
    Just wanted to share
    Paul
    Sterling Steel IGP lagoon 21' x 35' w/6' deep end, Pentair 5g LED lights (x2), Pentair Landscape LED light, Pentiar IntelliFlo VS pump, Pentair 420 Cartridge filter, Pentair IC20, 4 gas Tiki Torches, LoopLoc Ultra Loc II, Deck Jets(x3), Raised Planter Bed with 3 Pentair bronze sheer decents, AquaBot Breeze 4WD, Pentair Legend II
    Feb 2013
    Metro St. Louis
    93
    Re: New build in Metro St. Louis
    Before and during deck demo...
    Paul
    Feb 2013
    Metro St. Louis
    93
    Demo Done!
    Paul
    Columbus Ohio
    178
    Paul, looks great! We are about to start the process as well, in the next 3-4 weeks. We are building a new house and having it done at the same time. Our previous pool had a lot of the same equipment you are using. You will love the deck jets and the intellibright lights, we LOVED the color changing. The VS pump is great too, our electric bill went down when we installed it compared to the 1hp pump we had before. The only thing I see that I recommend looking into pricing for is getting a bigger salt cell, the ic40. Doing a bigger one means it will last longer, and you can set it on a lower setting hence the longer lasting side of things. It shouldn't be too expensive to upgrade that.
    Can't wait to see your progress!!! and good luck!!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    Feb 2013
    Metro St. Louis
    93
    Hi tatertot09,
    Thanks for all the great feedback! Sounds like we will be building at the same time
    For the SWCG...I was really on the fence about the sizing you mentioned. I read on here about oversizing 1.5 to 3 times for the exact reasons you mentioned. Our pool is 13,700 gallons...so the IC20 is about 1.5 times oversized...but the IC40 would be about 3 times oversized. I decided to error on the 1.5x as I heard getting closer to 3x could make for harder adjustments.
    However, the PB would probably not charge much at all to go from the IC20 to IC40 as you mentioned...if it would be much better.
    Good luck with your build!!!!
    Paul
    Jan 2013
    St. Louis, MO
    43
    I am new to the site and also meeting with PB to finalize plans, etc this week. Who are you using for your project? We are almost set to sign a contract with Pool-Tron.
    I can't wait to see pictures of the progress on here!
    Build under way:http://s1360.photobucket.com/user/jc...982/slideshow/
    42'-18' Freeform Shotcrete pool. 3'6"-8'6" depth. pebble sheen (ocean blue), IntelliFlo 4x160, Pentair Ultra Temp Model 120, System 3 Modular Media Filter, SWG
    Feb 2013
    Metro St. Louis
    93
    I have heard good things about Pool-Tron. We signed with Pool Pros.
    Paul
    Columbus Ohio
    178
    Ahh hearing how many gallons you have I'd say you made the right choice with the ic20!
    Feb 2013
    Metro St. Louis
    93
    Just met with the PB foreman. Seems really knowledgeable and accommodating.
    Only thing he strongly recommended was a Pentair Triton II sand filter instead of our current selection of a 420 cartridge filter. He said with all the spring pollen, we would need to clean the cartridges very often...possible once a week. Based on research here, it seems like the 420 cartridge would be very over-sized for our 13,700 gallon pool...and would require very infrequent cleanings. He said the Triton II with ClearPro Tech (TR60CP) would filter to a lower micron than cartridge as well....coming close to DE levels.
    He did say he would install either one no problem. Any thoughts before we give him the green light on the 420? Should we reconsider?
    Paul
    Feb 2013
    Metro St. Louis
    93
    Well, don't think they will be digging for a few weeks
    We got 9" of snow today...and it is still coming down. Crazy weather!!
    Paul
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I'm a little late but I will respond to your filter question. For a cartridge filter, we would recommend at least 210 sq. ft. cartridge filter, so your 420 is large, but you really can't go too large with a cart filter.
    Your pb advice is good to at least consider though, since pollen and for example cotton wood "cotton" can plug up a filter pretty fast. WIth that said, your large cart would still go awhile before needing cleaning. I am not a big fan of cleaning my cart for my hot tub, it is a lot easier to backflush my sand filter on my pool...but I do not have water restrictions, I can deal with my fill water quality issues etc. Also, if you are going with a swg, you might want to keep the cart (though sand and swg works for me).
    From Hydraulics 101:
    Which filter is best for you depends on your situation:
    Cartridge Filters: Most energy efficient and don't require back-washing. Best suited for areas with water restriction, high electrical rates and/or pools that use a SWG.
    Sand Filters: Easiest for algae clean up. Best suited for areas where the pool is closed for the winter and/or high algae potential.
    DE Filters: Best filtration. Best suited for owners that really want their water to be as clean as possible.
    [s:25ci82eh]If you do decide to go sand, then get a minimum of 3.2 sq. ft. sand filter.[/s:25ci82eh]See post below, should have been 2.6 sq. ft. minimum
    Jan 2013
    St. Louis, MO
    43
    Quote Originally Posted by geekfamily
    Yeah, this is depressing! Heading to pick out tile and stone today, maybe that will help???
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by linen
    I am sorry, I was wrong about this minimum size I should have said 2.6 sq. ft minimum for your planned 13700 gallon pool
    Hey Paul, it's me! Wondering if you guys will finally be able to get started? Looks like more rain this week, but maybe you'll get lucky!
    Chesterfield, MO
    In Ground vinyl liner pool
    - Lagoon Shape - 40'x30'x20'
    - Intelliflo VS Pump
    - Intellichlor Salt System
    - Triton II Sand Filter
    - Pentair MasterTemp Heater
    - EZ Touch Controller
    - Faux stone water feature with sheer descents
    - Turbo twister slide
    Feb 2013
    Metro St. Louis
    93
    Hi Bfassler! Good to hear from you Yes, they are supposed to start digging this week...planned for mid-week. With rain in the forecast quite a bit, not sure if that will happen. I am ready!! As soon as they start, I will be posting pics
    Paul
    Feb 2013
    Metro St. Louis
    93
    My wife came up with this idea...why not cut the solar cover using the pool outline. Thought it might be much easier than once the pool is in with obstructions. Maybe this is a rookie mistake, but seemed simple enough. Also got the pump area cleared out and ready to go.
    Paul
    Feb 2013
    Metro St. Louis
    93
    They started digging today!! PB had about 5 guys on site. They were prompt and courteous. Hopefully that is a good sign. The foreman was taking charge and really got everyone moving
    They demo'ed the existing patio, poured the pump pad, and are digging the hole now! We are not getting a heater, but having the gas line run for it in the future. The PB said since they are also in the pool service business, they like large pads for lots of room to work...and don't want to skimp with a tiny pad. The pad they poured is 4'x8'. That is for a pump, filter, ic20, and future heater.
    Only small issue is the steel pool panels (not on-site yet) have already been cut for the 2 led lights. I wanted to decide the locations, but am now limited. The good news is their locations are nearly the same as mine, except for the one by the stairs. Their location does not seem quite as good as I planned, but then again I have never seen the lights in action It is pretty close...so I think it will be fine. With 2 lights, my hope is we have adequate lighting.
    Pics coming soon !!
    Paul
    Feb 2013
    Metro St. Louis
    93
    Pics from first day
    Paul
    Feb 2013
    Metro St. Louis
    93
    More pics The PB has been working a ton. They worked all day yesterday and got most of the shell up, and were back out here today (Sat) at 6:45am
    Paul
  20. Back To Top    #20
    Feb 2013
    Metro St. Louis
    93
    The PB came out on Saturday and worked all day. They are planning to pour the concrete collar tomorrow (Monday). There is scattered rain in the forecast for all week. They want to get the concrete collar poured before any rain this week.
    Here are pics of the pump pad as they started on it. Does it look ok? I noticed they did not use unions for the pump, but mostly it looks good to me...thoughts?
    The wife wanted the steps moved, so the 5g light is pretty close to the steps now and might not work perfectly...but hopefully it is ok....the is a second 5g that should help.
    Does anyone know what all the metal rods/string are in the pool bottom?
    Paul
