Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 106
Thread: Help me get my pool ready
    Jan 2013
    Miami, FL
    100
    FC 4
    CC 0
    TA 90
    Calcium 230
    Cya 60
    Ph 7.8
    What is that stuff and how do I get rid of it?
    11k Gallon, Catridge Filter, In Ground Marcite, 1.5 HP Pump, (Unsure of filter Flow Rate)
    38,305
    Re: Help me get my pool ready
    Does it feel slimy? If so, it is algae. If not, try putting vitamin c on it and see if it fades ... that would indicate metal stain.
    My guess is algae. Read about the shock process in Pool School (button at upper right) to get rid of it.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    30,421
    Might be calcium scale with algae growing in it. Does it feel rough to the touch? Have you had high pH in the past?
    Jan 2013
    Miami, FL
    100
    I just received my test kit so I'm going to go ahead and shock the pool and we'll see what happens. I believe it is algae as it brushes of fairly easily. It just comes back though. Hopefully with added attention and testing I can get rid of it.
    I purchased this home after a foreclosure so there was a time the house sat empty so who knows what the pool has been through...
    If that is the shaded side of the pool that might be mustard algae.
    Jan 2013
    Miami, FL
    100
    I think that is the shaded side of the pool, I'll keep a better eye on the shade as the day progresses. It does seem like mustard algae though...
    I read through the Pool School section on Mustard Algae and I'm a little confused. It seems like I need to shock the pool and while it is at shock level brush everything. However, it seems like do do this I would have to go into the pool to brush the light area. Is this correct? Is it safe to swim in the pool at shock level?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Just use a mask if you need to go underwater and rinse yourself afterward. Usually what we mean by brushing is using a brush attached to a pole, which would help you avoid having to go in the pool.
    Jan 2013
    Miami, FL
    100
    I understand that you normally brush the pool from the outside but in order to get the niche for the light and the ladder I would have to be in the pool.
    So, after reading up a bit I have formulated the following plan:
    1- Reduce CYA to 30 by performing water change
    2- Reduce PH to 7.2 by adding Acid
    3- Raise FC to 18.2 by adding Liquid Chlorine for 24 hours and then brush the heck out of everything.
    4- allow the FC to fall to between 3-7
    5- Raise PH to between 7.5 and 7.8 by adding soda ash
    6- Raise Calcium level to between 250 and 350 by adding calcium chloride
    7. Raise CYA to 40 by adding cyanuric acid
    Questions:
    I skipped the normal shock listed in the mustard algae pool school article because my CC is already 0 and the water is crystal clear. Is that okay?
    Should I adjust the Calcium Hardness first? It is a little low but the main problem I have is he Mustard Algae.
    38,305
    No. You need to go through the normal shock process first. The clear water test means you can not see any algae anywhere.
    After completing the normal shock process, then you raise the FC higher fit the mustard algae.
    Lowering the CYA is optional, you are not that high. But shocking will be a little easier if you lower it.
    Jan 2013
    Miami, FL
    100
    Ok, I replaced about 30 percent of the water based on the pool calculator in order to lower the CYA. Any advice regarding whether to raise the calcium before or after the shock process?
    38,305
    Forget about all the other parameters until you finish the shock process.
    Just adjust the pH, and once that is set, you only need to be testing for FC and CC until the shock process is complete.
    Then you can adjust everything else as required.
    Jan 2013
    Miami, FL
    100
    Update: During the draining process I managed to run my pump dry because I left the pool cleaner on and it must have gotten stuck above the water line. I should have just used the "drain" to drain the pool. So, yesterday I slapped on a spare pump I had and I'm back up and running.
    Current Parameters:
    FC 0
    CYA 40
    TA 80
    PH 8.2
    After testing I cleaned the filter, vacuumed, and slowly poured in what little acid I had. It is not going to be enough to lower the PH to 7.2 so I am headed out to get some more acid. How long should I wait to test ph and add more acid?
    38,305
    An hour is plenty of time.
    Jan 2013
    Miami, FL
    100
    Update:
    Tested PH about 45 minutes ago 7.6
    Added 2 cups Acid
    1.5 Gallons Chlorine
    Brushed Walls
    Will test again in 15 minutes and post results...
    Jan 2013
    Miami, FL
    100
    Current Parameters
    PH 7.5
    FC 16
    CC 0
    Now I'm feeling kind of dumb, my plan was to get the PH to 7.2 but I jumped the gun and added the Chlorine thinking the acid I added would lower the PH to where I wanted it.
    So, should I add more acid or just monitor the FC?
    The PH test tends to read a little high when FC is above 10. Because of that it is generally best to ignore the PH test until the FC level is back below 10.
    Jan 2013
    Miami, FL
    100
    Great so FC and CC only for now... So, my last test was right at shock level. Should I add a little chlorine now or wait until it falls below 16?
    Jan 2013
    Miami, FL
    100
    I added a little more chlorine after the last test.
    Current Parameters:
    FC 19
    CC 0
    Filter 12 PSI (Same as after the cleaning earlier today)
    I'll test again once more tonight before turning in...
    Jan 2013
    Miami, FL
    100
    FC 17
    Psi 12
    Added some more chlorine
  20. Back To Top    #20
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    I assume you will check in he morning early to see how much FC you lost overnight.
    - Sent using Tapatalk
