Thread: Run pump prior to testing?
    Valley Forge, PA
    32
    I'm curious about this. I usually test my water at about 6:00 pm and my pump starts running for the second period of each day at 4:00 pm. On the weekends, I sometimes test earlier. Should the pump be running for a certain period of time prior to testing?
    30K gal in ground shotcrete pool with Sunstone Select finish
    Attached raised spa with spillway
    DE filter, 400K btu heater
    Ray-Vac cleaner - replaced with Letro Legend 2
    Use BBB methods
    To get the most consistent results the pump should be running for 30 minutes to an hour before taking a water sample.
    Valley Forge, PA
    32
    Thanks
    Thank you, sir.
    Use BBB methods
