Results 1 to 9 of 9
Thread: Motor electrical question
    Dec 2007
    Phoenix AZ
    5
    I recently had my Hayward Northstar pump in to repair a link. The tech connected the electrical to spin the shaft and sand it. He then replaced the Shaft Seal Assembly and reassembled everything. When he went to test it he connected the 220 volts to the brown and white wires instead of the 2 connections that are inbetween the 2 wires. He said that would not be a problem but could not get the motor to run on 220 and said his pigtail must be bad.
    Now I have pump home and it will not work on 220. It did worked plugged into 110 volts.
    Is there a fuse or internal circuit breaker that poped when it was wired incorrectly?
    Thanks
    23,000 Gal Pebble Tech
    Hayward C4025 Cartridge filter
    Hayward 1.0 HP
    Autopilot SWG with SC-60
    TF-100 Test Kit
    38,305
    Re: Motor electrical question
    I do but think there are any internal fuses. Generally the wiring connections inside are different between the 220 and the 110 setup. I would triple check the 220 wiring compared to the diagram.
    Can you post pictures?
    Posted from my Droid with Tapatalk ... sorry if my response is short
    22,551
    Posting a pic of the wiring diagram on the data plate will help. Are you sure that you're getting the correct voltage to the pump?
    mas985's Avatar
    Pleasanton, CA
    11,741
    There isn't a fuse inside the motor but there is a thermal limiter switch which has a separate connection for 220v vs 110v. So because the tech hooked it up incorrectly, it is possible to damage that switch. But the windings should be ok since 110v works (both voltages use the same windings). If you have an ohm meter, you can check the winding resistance (power disconnected) when wired for 220v. The resistance should be 1-2 ohms. If it is an open circuit, it could be the thermal limiter switch.
    Mark
    Dec 2007
    Phoenix AZ
    5
    I just checked the voltage and resistance between the different contacts, A, B, L1 and L2. Voltage coming in is at 247 volts
    Measuring the resistance, most circuits were open. Only the A to L1 and B to L2 circuits were shorted.
    Is the thermal limiter switch easy to get to and check/replace?
    Hayward 1.0 HP
    TF-100 Test Kit
    jkurl's Avatar
    Fairfield, ca
    141
    He could have possibly damage that portion of the motor. If it has a protection circuit or a circuit that limits the voltage it could have instantly damaged it. The motor does have the ability to wired for either 110 or 220 did you check to see if that might have gotten changed the other thing is it might have a 110/220 switch. If it does check that switch it could have gotten switched by accident.
    Please take a pic of the wiring diagram on the pump. Should be two 110v lines and one ground. They should be interchangeable on one video I watch of a hayward pump replacement.
    Pool Size: 20 x 40 Free Form Inground Plaster Pool w/ a shallow cove.
    Gallons : ~23K Jandy CL580 Cartridge Filter, Jandy e-pump 1.5HP
    Polaris 280 w/ Booster Pump, AqualinkRS PDA4 Remote, Aqua-Pure SWG
    Jandy LED Pool Lights (2), Heliocol 500 Sq. Ft solar rack system
    mas985's Avatar
    Pleasanton, CA
    11,741
    The proper wiring for the motor in 230v mode should be White to B and Brown to A and there should be 1-2 ohms of resistance between terminals L1 and L2. If that is open, then it is likely to be the thermal limiter switch. I have never replaced one myself and doing a quick search, I am not sure you can get one on your own. However, a motor repair shop should be able to repair it if it is damaged. But since the tech caused the problem, he should fix it.
    Mark
    jkurl's Avatar
    Fairfield, ca
    141
    Quote Originally Posted by mas985
    Mas I agree 100% about having the tech fix it.
    Dec 2007
    Phoenix AZ
    5
    Thanks all. back to the shop it is.
    Hayward 1.0 HP
    TF-100 Test Kit
