Results 1 to 9 of 9
Thread: Will my basketball hoop fall over?
    Hello,
    I am having a paver patio set around my inground pool next month. I would like to install the SR Smith Salt Friendly Basketball Hoop which uses anchors that accomodate the 1.90" outer diameter dual poles. I plan to use the 6 inch deep bronze anchors (model AS-100D) distributed by SR Smith designed for this purpose. The manufacturer's instructions assume the entire 6" depth of the anchor is embedded in poured concrete
    My question and concern is this: Since it is a paver patio, and each paver is 2 and 3/8 inch thick, that leaves a maximum of 3 and 5/8 inch that would be anchored within the concrete pad that will be poured and lie underneath the involved pavers ( the rest of the patio will be compacted gravel with 1 inch of sand over it and pavers on top). This assumes the pavers lie directly on top of the concrete pad.
    Do you think that the lower 3 and 1/2 inches or so of the bronze anchor embedded within the concrete will be enough to hold the basketball hoop securely?
    Thank you
    37,000 Gal (21 x 44 ft) Gunite, Pebblesheen
    Sta-Rite Two-speed, 2.0 HP filter pump
    Sta-Rite Cartridge Filter, 450 sq ft
    Sta-Rite 400,000 BTU propane heater
    Pentair Intellichlor Salt Chlorine Generator, IC-60
    Pentair IntelliTouch i9 + 3 Pool & Spa Control System
    Pentair Mobile Touch 2 wireless control
    Polaris 280 Cleaner with booster pump
    TF-100 Test Kit
    30,419
    Re: Will my basketball hoop fall over?
    3.5 inches of concrete is a boatload!!! the post will surely be immovable. I doubt you need to be the least concerned
    Nov 2011
    Moberly,MO
    1,010
    No 3 1/2" is not enough. Why would SR Smith recommend 6". To insure that the pole doesn't get pulled over into the pool and someone get hurt or the pool damaged, that is why. Do as the manufacturer recommends for the safety of your family members.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    30,419
    Overkill and to cover themselves is why they suggest 6". A bronze anchor embedded in 3.5" of concrete could not be pulled over by a car! I can't imagine a scenario where someone can dislodge an anchor using a 3-4 foot tall basketball hoop. Honestly, I doubt Shaquille O'Neal could do it swinging from a regulation 10' goal but, if you are planning on having him over, I might go 4.5"
    Thank you for the replies. Does anyone have another opinion one way or the other?
    Is there another product that I can use? Does anyone know of a bronze anchor that is longer than 6 inches that accepts a 1.90" diameter pole?
    If not, I might have to give it a try with the 6 inch bronze anchors partially embedded. I know there are plastic anchors on the market that are a bit longer but my concern is that they will crack.
    TF-100 Test Kit
    Jun 2012
    Louisiana
    47
    I'm not familiar with the anchors, but what about pouring footings for the anchors to be embedded it. You could use 6" PVC pipe for the forms and pave around the anchors at ground level. Just an idea...like I said I'm not familiar with the anchors or the profile sticking out of the ground. If this idea doesn't work, maybe it'll spark an idea for something else that will.
    25,000 gal Plaster; Hayward 1 hp Super II; Hayward Vari-Flo XL Filter
    Nov 2011
    Moberly,MO
    1,010
    Contact SR Smith and ask them. Personally I wouldn't take the risk. My family is more important than a little concrete. But that is my opinion
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    We'll what did you end up doing, how did you do it, and what have the result's been?
    How do you like this basektball goal? One or two post system?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    I did what I initially thought I would do. I had them embed two 6 inch x 1.90 inch dia. SR Smith bronze anchors (AS-100d) in concrete 17.5 inches apart for the the two-pole salt friendly basketball hoop. The anchors are embedded about 3 and 5/8 inch in a poured concrete pad (which is about 3 x 2 feet x 12 inches deep) with the pavers over the top of the pad. In retrospect, my concerns were almost silly. Those anchors aren't going anywhere. The hoop is rock solid and completely immovable. I've got some big 15 year old boys kids playing with it and its been fine.
    The kids love the basketball hoop and it seems like a quality product.
    I also used several additional AS-100d bronze sleeves for umbrella pole anchors in various locations around the deck, which turned out to be a great idea. The 1.90 inch sleeve sizes accommodate many over-sized umbrella poles. To get a standard 1.5 inch pole to stand up straight, I simply cut 5 inch sleeves of sch 40 pvc and slid them into the as-100d's where needed. I forget the size of pvc for this off hand- I think it is 1.5 inch sch 40 which has an outer diameter of 1.90 inches- it fits the AS-100d sleeves perfectly.
    The hardscape contractor anchored each one of them in a similar way as the basketball hoop, but simply buried half a cinder block, embedding each sleeve in concrete which they poured in the center cavity of the block. I was a little skeptical that would hold the umbrella sleeves securely but he assured me they would with the base compacted around the block and the pavers on top. So far, no problem. They are solid.
    Hope this helps.
    TF-100 Test Kit
