Results 1 to 7 of 7
Thread: 10 gallons of liquid bleach left over from last year
    Topic split off. Please ask questions in your own topic instead of reusing someone else's existing topic. Thanks JasonLion
    Staying with the expiration topic, I have about 10 gallons of liquid bleach left over from last year. I stored them in my basement so they would not freeze. Are they still good to use this spring?
    Installed Sept 2008. 18 x 36 Flatback Kidney Radiant, Vinyl liner 25,000 inground, Hayward Max-Flo 1 HP Pool Pump SP2807X10 (runs 24/7) , Hayward Pro-Series High Rate Sand Filter Model #S244T, Hayward Heat Pro, Frog chlorinator is turned off, TF-100 Test kit
    Location is Toronto, Ohio, overlooking the Mighty Ohio River. My river days are done. Sold the boat and Waverunner and now prefer a pool over the river.
    22,553
    Re: 10 gallons of liquid bleach left over from last year
    It's possibly a little less strength but it's still good to use. Add what the pool calc cals for and then test about 30 minutes later and you'll know if it's still abot the same strength.
    Thanks Dave.
    Last season I started off with a few gallons of 10% left from the prior year. This year I will be again using left overs from the prior season. I didn't notice any measurable degradation. I doubt the garage gets much lower than mid 40s in the dead of winter.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Feb 2013
    Yukon, Oklahoma
    220
    Just for future information, doesn't heat truly effect the bleach more than the cold? I have been advised to keep my bleach in a dark and perferably room temperature room/location because heat and sunlight killed the bleach. I did test that out last year and was suprised at how fast bleach looses it's effectiveness when a bottle is left outside next to the pool (because someone forgot it).
    Bob E.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, as shown in the table at the bottom of this link, bleach and chlorinating liquid degrade more quickly at higher temperatures so last longer at colder temperatures. They also degrade faster at higher concentrations. So 6% bleach in a cool environment will last quite a long time.
    Casey's Avatar
    SW PA
    10,461
    I had 5 big jugs of the 6% that I didn't use in 2010 when I took my pool down due to divorce. I cleaned my new house and did laundry with it. As a matter of fact, I still have some of it under the kitchen sink! lol
