View Poll Results: Which heater would you choose for our pool?
Voters
3. You may not vote on this poll
  • Jandy Hi-E2 - $12,000
    0 0%
  • Pentair PowerMax - $10,000
    0 0%
  • Lochinvar Sync - $35,000
    0 0%
  • Raypak Xtherm - $35,000
    2 66.67%
  • None of the above.
    1 33.33%
Thread: Commercial Pool Heater
    I'm looking for some advise from people who aren't trying to sell me something!
    I'm with a non-profit organization which has a 35'x75', 110,000 gal indoor pool which needs a new heater after the 15 year old unit sprung a leak in it's heat exchanger. The old unit was massively oversize, so I'd rather not base sizing off of it. We're looking at sizes between 500K-750K BTU's depending on the unit and cost. Does that seem right? The old unit was 1.8 million BTU's and was definitely too much - they may have been using the pool to heat the room when it was put in 15 years ago.
    Now we have a high-end HVAC system to keep our air temp ~83' year round and would like to maintain an 80' water temp. Our ventilation system also monitors humidity. The first 5 days without heat the pool temp dropped 1' per day until slowly settled out around 71' where it has remained. Temps outside have been 30' or so.
    We have no limits on size or restrictions on plumbing/gas line placement or sizing.
    We're looking for a natural gas heater with:
    • - CuproNickel or better heat exchanger,
    • - the ability to duct intake air - to keep the DE and chemicals from getting sucked in
    • - exhaust through a side wall (4' or so from the unit),
    • - high efficiency as reasonably economical
    • - easy to maintain and trouble shoot
    • - Longest serviceable life
    Units we're interested in:
    Pentair PowerMax / Laars Pennant
    Positives: All the above, plus :85% efficiency, sealed combustion, low nox, about $10,000
    Low bid of the ones listed here - meets our minimum standards and should get the job done. Will it last? Sales rep not knowledgeable about maintenance long term. Said 'it needs no maintenance.' Sure...
    Jandy/Zodiac? Hi-E2
    Positives: All the above, plus: 'up to' 98% efficiency, vent through PVC, about $6K each
    Only one size available. We would likely need 2 for our needed max capacity - perhaps they could be staged as needed however. Seems to be more for residential use.
    Lochinvar Sync or Raypak/Rheem XTherm
    Positives All the above, plus: fully modulating condensing combustion, Stainless Steel Heat exchanger, the Lochinvar 'features' smartSync controls ~$35,000
    Expensive - but maybe it's worth it? Could be harder to maintain/easier to break fancy things. Can't find much info on the Raypak...
    So - Which others should we consider?
    What do you think about these units? Do any standout better than the others? Any you'd avoid?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Commercial Pool Heater
    We stopped using boilers for our commercial installs some years back and have gone to multiple Raypak heaters (400K). Takes a bit more plumbing. Have not priced the difference, but i think might be a little less expensive alternative for you. Typically we use 3 to 4 400Ks depending on application.
    Factory Warranty Station for:
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    http://www.astralpoolusa.com/products/r ... gas-heater
    Check out a real high efficiency heater. Yes it says residential but I would check them out. Saw it at a pool show recently and looks promising.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Definately go Raypak. We have the best luck with them and their warranty. You can manifold residential heaters together to help achieve the same thing as a commercial purpose built heater, but its not really recommended. Look into the Raytherm WH-962 with the cupro-nickel tubes, for a cheaper alternative. The Hi Delta WH8-992B is a good one also.
    PremierPoolProducts.com
    Premier Pools and Spas | Omaha, NE
    Stanger General Contracting | Omaha, NE
    Swimming Pool Design/Build Specialist | Consultant | Repair | Parts | Service
    Certified Warranty Station for Pentair | Hayward | Zodiac/Jandy | Aquabot | Polaris
