Thread: Blower motor not working
    I have a blower motor that is turning on and it sounds good, but it is not forcing any air into the spa. The blower motor is positioned below the water level of the pool by about a foot. A couple feet below the blower is a check valve. Is it possible that the back pressure of the water against the check valve is to great for the blower to force the check valve open?
    22,553
    Re: Blower motor not working
    It could be that the check valve is just stuck and the air pressure isn't enough to open it. Once you un-stick it, it may work fine.
    Have you ever seen the blower work?
    never seen it work. but i took the check valve out and lubed it and it is still doing the same thing
    22,553
    It's most likely not producing enough pressure to overcome the water head pressure. You could use a low pressure gauge or rig an "inches of water" gauge out of a piece of clear tubing and connect it to the blower pipe to see how much pressure it's producing.
