Thread: new valve for Triton II sand filter
    Feb 2013
    134
    I'm spec'ing out replacement filter setup - looking at TR100 4.9 sq ft Triton II filter from Pentair. I currently have a multiport valve on my 3.1 sq ft unit, so that's all I'm familiar with.
    I see push-pull valves on the website as alternative - what are the pros and cons vs multiport? Do I still get all the filter/backwash/recirculate options with push-pull that I do with multiport?
    25K gal IG plaster pool w/ spillover jacuzzi, 12 Gulf Solar coils (leaking/currently bypassed), ancient Raypak propane heater (rusted/currently bypassed), Pentair 001018 VS pump, 4.9 sq ft Triton II sand filter, Taylor K-2006 FAS-DPD kit
    38,275
    Re: new valve for Triton II sand filter
    Push-pull is the basic unit that will give you filter and backwash ... that is it.
    The multi-valves are much more flexible by adding all the other options.
    Feb 2013
    134
    got it - multiport it is. next question: 1.5" or 2" valve? my current pump is 1.5" on the pressure side, is there any advantage of going to 2" or is it not compatible? http://www.sunplay.com/Pentair-Multipor ... 261055.htm
    38,275
    Generally best to go large on the pipe to lower head loss.
    Posted from my Droid with Tapatalk ... sorry if my response is short
