Thread: Deck level is slightly lower than pool - how to do surround
    Hi Guys,
    I see you guys have a brilliant solution to decks with your pool rim able to be built on.
    I have a disaster where the pool rim is higher than the surrounding deck, and the rim of the pool is NOT allowed to take any load.
    What would you suggest in terms of pool surrounds, as we have to repair most of our deck as it has rotted.
    Currently we have ugly ply wood, that sits on top of the pool rim when it shouldn’t.
    Cheers Paul.
    38,301
    Re: Deck level is slightly lower than pool - how to do surro
    Welcome to TFP!!!
    If most of it is rotted can you raise it a bit?
    Alternatively, could you add a step-up around the pool that would cantilever out and cover the pool walls?
    Now ... I defer to those with actual experience
    Welcome to TFP!!!
    Thanks for that, and a good idea, I was amazed to find a pool website, very cool
    4knights's Avatar
    NE Kansas
    419
    I agree with jbizzle. Pull the bad and going bad wood then you can either add a stepped cantaliever or even a smooth sloped transition cantaliever (would require some wood working skill or trail and error for a DIY guy) My dad and I built a deck surround for one of the Intex self supporting pools. The deck held all the weight so folks could actually sit on the edge and dangle their feet. Can't do that with an inflatable ring.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
