Results 1 to 11 of 11
Thread: Fire Ants and a filter pump
    Aug 2007
    Athens, AL
    42
    I had noticed that a fire ant hill was building over by the filter pump and I was planning on taking care of it on my day off, today. As I was walking my wife out for her to leave for work, I decided to run the filter for a bit......I flip the switch and hear the power hit the pump but no go. Could the fire ant hill have stopped the motor and if so, is it permanenet.
    I am now boiling some water to put on the hill (my wife;s idea because the dogs go back there too)
    As always, TIA, thanks in advance
    Tony
    ______
    My Pool set up:
    28,000 gal, 40x32x16 True "L" IGP, 3-8.5 ft depth, Hayward 1.5hp Super Pump, Pro Seriews 300# sand filter, 2 skimmers, 3 returns, Barracuda III suction cleaner
    Apr 2008
    Central Texas
    326
    One word: Amdro. That stuff kills fire ants, the complete mound.
    As for the pump, they may have gotten into the pump motor and filled it with soil. You'll need to look carefully. Perhaps just a good rinse with a water hose will get the dirt out.
    Be very careful working around the ants. Their bite hurts for quite some time and raises a small blister. Ant and Roach Spray will kill the ones that are above ground while you're working. 8)
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Oct 2007
    Valrico, FL
    542
    It is strange, but I have noticed that some ants are attracted to electricity! I would not rinse out your motor with water! If you do, take it apart, place all of the pieces in the sun for a week to dry off. Water and electricity do not mix. More likely the ants go in to the starter switch and is now not makeing contact. Open up the end of the motor away from the pump and blow it out using a vacuum cleaner and clean air.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I read an article this past week about southern Texas being infested with "crazy rasberry" ants, and that they love to congregate in electrical boxes. Too weird!
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Apr 2008
    Central Texas
    326
    The motor is rated for outdoor use, so I don't think that a bit of water will hurt it. However, I would make sure that the power is off first. I washed my entire equipment sertup with the pressure washer this weekend to remove the dirt, pollen, etc. that was all over everything. It looks brand new again.
    Polaris 280
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Even though the motors are designed for outdoor use, they may not be resistant to sprayed water.
    Electrical equipment is rated from Grade 0, no water resistance, to grade 8, continuous immersion. Grade 4, splashing water, is good enough for most outdoor equipment, but it takes grade 5 to be hose proof, and grade 6 to be pressure washer proof.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    If you have an air compressor I would just blow the air through the pump to see if you can flush the buggers out. It might just be a debris connection issue. If they come out kill the buggers!!! I live in SC came from the north where there aren't any red ants. I HATE RED ANTS!
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    I have seen pump motors shorted out by ants. In fact, opening up the back of the motor I found it was filled with dead ants. The compressed air idea sounds like a good one to me. Blow them out and then check where the wires connect in the back to see if there was a short.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    The compressed air idea sounds like a good one to me. Blow them out ...
    I suggest you use good eye protection. The last thing you need is an eye (or two) full of fire ants.
    Apr 2008
    Indonesia
    311
    Yep, ants are nasty.
    I am now still looking at a short circuit in one of my lights on an outdoor wall. The cable live to neutral reads 5 kilo Ohms and that produced slow short circuit. I am trying to find where the juction box which most likely being buried in the wall..****...so sad. The connection at that junction box I suspect of having dead ants or being an ant hotel. Happened before on a garden light connection.
    Yes, use air blower. I clean the end part of my motor with compressed air and I use my scuba tanks... , the dust is massive but its worth cleaning or else heat transfer will be much restricted.
    35,000 GL pool. In Ground. Concrete with all white ceramic tiles. Outdoor but shaded.
    Approx 36 ft by 15 feet. 2HP Hayward Super Pump, Hayward Sand Filter with Zelbrite ( Zeolite ), Hayward Cartridge Filter, Aquamatic Silver+Copper Ionizer ( suspended use since Oct 2008 ), Prozone Ozonator, 2 gram/hr, Analog Flowmeter on pipe
    Back Up Pump & Filter on trolley, Pentair 1.5HP + Pentair Cartridge Filter, Slime Bag 1 micron Jumbo Size, downstream of Cartridge
    Aug 2007
    Athens, AL
    42
    The ants are gone
    I rinsed out the motor and all is well.....
    Tony
    ______
    My Pool set up:
