Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: What specs do I look for re: buried AGP
    I have spent hours on this site and I'm still not clear on it all.
    We want to bury an AGP. At least 3/4 of the way or close. We want the most pool for our money but safety and quality are more important. I'd like a pool that will last us a while since this is a big project for us (BTW, this is a self install...DH is handy and has many handy friends).
    So I'm looking at pools that are rated as semi-inground but I'm not seeing how that makes them better than some other pools (not SI rated) with similar specs. I feel like I'm paying for them to say, "yes, we will allow you to bury this."
    So my question is, what is necessary for a buried AGP regarding material of uprights, walls, etc.?
    Also, if we wanted to buy the pool at one place and later buy a pump at another, is there any caveat to that?
    I'm hoping to spend about $2k or so on pool, liner, pump, filter, and stairs. Would love to hear any comments on that budget.
    Thanks so much!
    Vette, DH, & 2 DDs Our IG AGP Build
    In-ground Radiant 24', 1.5 Pentair IntelliFlo pump, Hayward Sand Filter
    Oct 2012
    Central Ohio
    180
    Re: What specs do I look for re: buried AGP
    What size pool are you looking for?
    The biggest problem is warranty,if the pool manufacturer says it's OK to bury an above ground pool 12" and you bury it 24" you'll void your warranty.How far you can bury a pool is unique to each manufacturer/pool model.
    http://www.doughboy-pools.com/Products/ ... round.aspx Probably not going to come in under budget.
    You could buy a 24'x54"round pool,liner,Filter & ladder for $2000-$2500.That wouldn't include site prep,sand,electrical work or shipping.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Funny, I was just reading some of your old posts!
    I'm just wondering how important a warranty is. Especially if I'm doing a home install. If a DIY is an automatic void, then I have more pools to choose from.
    I'm looking at 3 pools right now.
    Poolfactory has a SI rated Quest w liner for 1785.
    Poolsupplyworld has the sharkline Venture w liner for 1660
    It also has the Matrix for 1770.
    All 24 x 54 and all seem to be of similar structure. What will it all boil down to?
    Also, I asked DH about a retaining wall and he said it would be too expensive. Put us way over budget. :/
    Oct 2012
    Central Ohio
    180
    A DIY doesn't necessarily void your warranty.
    "What will it all boil down to?" It boils down to"Can the pool structure support the weight of the soil/fill pushing in on the water filled structure,will the structure handle corrison due to it being buried.Also if you bury it you may not be able to drain the pool without it collapsing.(difficult to replace a liner)
    I'm not trying to dissuade you I just want you to see the whole picture.
    Rob
    SWCG,Uni-bead liner
    Borates
    Right. So what's to say the non SI rated are any worse than the SI rated?
    Really, what I want to know is what are the basics for a pool to be buried? So many inch posts, this kind of coated wall, etc.
    Oct 2012
    Central Ohio
    180
    About the only thing that says whether or not you can semi bury an above ground pool is the manufacterer,local codes and you.
    Some of the Semi-inground pools have a little heavier wall,but not all of them.
    Rob
    SWCG,Uni-bead liner
    Borates
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Well, mine is 52" deep and it is stated in the warranty that it is allowed to be buried up to two feet deep. There are also specifications regarding the type of backfill and how it is done. I don't think there's gonna be much difference in any steel wall pool you choose except the warranty and their rules regarding burying it. READ THE WARRANTY!
    I like the idea of it being buried 2 ft and then have a small amount of decking around it.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Thanks for everyone's comments. I've picked out the 24' x 54' Sharkline Heritage or Venture, but I'm leaning toward the Venture because of the resin ledge. Any solid reason to pick the Matrix over either of those?
    I've also tentatively picked out the Hayward Power-Flo 1HP 2s pump, Pentair SD60 filter, coving, and gorilla pad. Or should we get the Pentair Dynamo 1HP 2s pump to match the filter - does that really matter? Also, I live in middle GA where it gets hot as Hades and we may not close a pool, so is sand the best option for a filter?
    Thanks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Vettechick99
    The SD60 is right on the edge of being well sized for your pool. We recomend a minimum of 2.5 sq. ft. sand filter for your proposed ~13500 gallon pool, so the SD60 at 2.3 sq. ft. is pretty close.
    No need to keep the same manufacturer, but you can find the SD60/ dynamo 1.5 hp 2 speed as a combo for a good price.
    You will find many opinions on this. Do you commonly have water restrictions? What is your fill water source...is it high in metals including iron and/or calcium? Are you planning on using a swg? I personally like sand, but answers to the above questions might sway towards one type or another.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Is there a specific reason for the Gorilla Pad?
    22,551
    Quote Originally Posted by cramar
    NutSedge is the number one reason I can think of!
    There are others of course, like rocks or roots puncturing the liner but Nutsedge growing through the liner is the best reason I can think of to use it.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Yes, I have it on my pool, I'm inquiring because some people believe it's used for padding/comfort and Gorilla pad offers neither.
    I've read it was just for protection, but the name does imply it's a pad. I wouldn't have known if I hadn't read it here.
    What stairs are these? Custom?
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Unless you have a concern about nut grass, stones, roots etc you don't need Gorilla Pad, it will not add anything in terms of comfort for the bottom, that is a completely different product.
    Casey's Avatar
    SW PA
    10,450
    Those are pretty cool steps vettechick. I've never seen an above ground pool in that shape.
    [/quote]You will find many opinions on this. Do you commonly have water restrictions? What is your fill water source...is it high in metals including iron and/or calcium? Are you planning on using a swg? I personally like sand, but answers to the above questions might sway towards one type or another.[/quote]
    I have city water so occasionally we will have water restrictions, but we've had a lot of rain this year and the rivers are overfilled, so I don't think we'll have any this year. We haven't in a few years. If we do, we can water only on certain days, but we can still do some watering. IDK if we have high iron or calcium. I do not plan to use a SWG.
    And I haven't seen many people talk about a timer, but I would need one unless I wanted to manually turn on my pump right?
  20. Back To Top    #20
    22,551
    ...And I haven't seen many people talk about a timer, but I would need one unless I wanted to manually turn on my pump right?
    That is correct. The gold standard is the Intermatic mechanical timers but there are all types and styles out there.
