Thread: New ladder for Intex Ultra Frame
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    After two seasons, the ladder for my Intex Ultra Frame could use replacing. It is rusting pretty badly, probably in part because I also have a SWG. I would like to get a new ladder that's mostly resin to avoid the rust. I am thinking about this one.
    http://www.saveonpoolsupplies.com/Pool- ... ol-Ladder/
    Would this work with an Intex Ultra Frame? I'm guessing that I would just place it over the wall like with my old ladder. Any thoughts?
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    Apr 2012
    SW Ohio
    456
    Re: New ladder for Intex Ultra Frame
    That will work nicely i would also recommend a pad for under it i think you have to fill it up with water so it don't float.....nice choice......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Yes, it will work. Get the pad for it too
    20 x 48 Intex Ultra Frame
    Sand filter with SWG attached.
    Deck added on (05/18/2013)
    Thinking about adding more deck
    Pool steps added in - (got rid of that crappy ladder that came with Intex pool) 05/18/2013.
    "A little bit of paradise in our yard"
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Great, thanks! Just wanted to make sure that the ladder didn't have to be somehow attached to the pool, which would not be possible with an Intex. I've found several ladder pads, but they have pretty negative reviews. Any suggestions on that?
    Intex SWG
    Feb 2013
    Yukon, Oklahoma
    220
    I am getting the Confer 7200 for my ultra frame 16 footer. I looked at the one you are looking at also. I went with the Confer because I wanted a little wider and deeper step. Certainly what you have chosen will be leaps and bounds above the stock Intex ladder that I too have put up with for the past two years.
    Bob E.
