Results 1 to 9 of 9
Thread: Very High Salt Reading
    I live in Florida and we recently had a lot of rain. My display read 2600 (I usually keep it at 3000) and my inspect cell warning also came on. I added a couple bags of salt and now it's reading 7100!! - would a dirty cell cause this? I haven't cleaned it yet but all I've read here is low readings on bad cells, not high. I tried removing the cell last night but it was so tight I couldn't get it off without some kind of tool which I don't have. I'll try again today; any advice is appreciated. Thanks, T
    Re: Very High Salt Reading
    Welcome to TFP!
    If you just added the salt, it probably hasn't fully dissolved and mixed in uniformly. In the first several hours it is fairly common to see dramatically fluctuating salt levels as the salt slowly mixes in. I would give the pool 24 hours with the pump running and the SWG off before trusting the salt reading from the SWG.
    A dirty or worn out cell would result in salt reading lower than actual, not higher.
    If you are in North Florida, it could be that your original low salt indication was caused by cold water that was outside the parameters of the temperature correction circuit. Most SWG's do not read accurately when the water is below approx 55-60 degrees.
    Start with an accurate salinity test done by a pool store or by yourself and once you know what it really is, we can offer more advice.
    Don
    Don Uhle, Discount Salt Pool
    I live in Tallahassee so yes, we've had very cold weather but it's been a week since the incident. When the inspect cell warning came on I held down the diagnostics button to clear it. I then added salt, turned off the chlorinator and ran the pump all night. The next day when I turned the chlorinator back on again it was giving the funky reading (7100) which it has never done, no matter how cold it is. Does this mean the cell is fried or can calcium buildup in the cell cause the false reading? Thanks again everyone, your help is appreciated.
    No, calcium scaling would cause a lower than actual salt reading.
    One more question
    if I accidentaly set my chlorinator to the wrong type of T-Cell number, would that cause a whacky reading? and if so, how do I adjust it? Thanks again.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Yes, definitely. If the cell type setting is smaller than the actual cell, the salt reading will be higher. The settings for the cell type are in the controller and the instructions should be in the manual.
    Mark
    Can someone tell me how to set the correct cell size
    on the generator? The manual doesn't explain how to toggle between 5 or 15.
    mas985's Avatar
    Pleasanton, CA
    11,743
    What system do you have (Make/Model#)?
    What is the software version #?
    Mark
