Thread: Hayward 5060 pump parts
    Round Rock, TX
    529
    I need to replace the metal ring that attaches the pump seal plate to the pump face (volute). Don't get confused with the technical terms, I just googled the parts
    Is this metal ring part of the seal plate kit? The pictures I see on the web do not show it, they just show the "spacer" that goes between the motor and the pump.
    I have had a little leak from the pump output and over the years it has rusted away the ring. I was planning on replacing the the ribbon gasket as well as fixing the pump output to ensure the leak is addressed at the same time.
    Ideas on where to get the metal ring?
    thanks,
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    22,548
    Re: Hayward 5060 pump parts
    I think it's part of the seal plate.
