Results 1 to 17 of 17
Thread: TA Test
    Jan 2013
    League City, Texas (South of Houston)
    39
    TA Test
    Our PB finished construction last week and is in the process of acid start up. I decided to run the initial test on my pool water and the TA test has me a bit perplexed. After adding the two drops of R-0007 and five drops of R-0008 the solution turns pink/red and not green.
    Does this mean I have no TA or is the test not valid with an extremely low PH?
    Shannon
    15.7K, IG Sunstone Pearl, 2 - Skimmers, 6-Returns, 2HP Jandy Stealth Pump, 580 SF Cartridge Filter, Jandy Aquapure 1400 SWG, Polaris 280, Jandy Aqualink PDA, Del Ozone EC-2, 10' Diameter Sunken Swim Up Bar With Palapa (built in Kegerator set at 27o), 2 - Jandy LED Lights, Weeping wall with 5 returns, Bubbler in Tanning Ledge
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: TA Test
    What's the FC level? pH level?
    The R-007 is a chlorine neutralizer. If you have really high FC it might skew things. I do know it often causes it to go from green-pink to blue-yellow.
    The other possibility is static electricity buildup on the R-008 bottle tip. Wipe it with a damp paper towel before testing.
    A final thought: a while back there were a few posts about defective R-008 reagent. How long ago did you buy the kit?
    Jan 2013
    39
    Re: TA Test
    The water being tested has no chlorine in it at all, so I din't even test that. The only thing added to the water so far has been 6 gallons of MA for the acid start up. Chlorine starts today.
    Jan 2013
    39
    Re: TA Test
    I just received the kit a week or two ago. The PH is well below 6.8 I do not have a PH titration kit, so I can not tell you exactly how low.
    Jun 2011
    Long Beach, CA
    2,790
    Re: TA Test
    Try testing some tap water, that should be above zero. If that works, I would say your pool TA is really low.
    Re: TA Test
    From the Extended Test Kit Directions:
    If the sample turns red, pink, or yellow, you are done, your TA is zero, and your PH is very very low.
    So, your TA is zero, and your PH is really really low.
    Jan 2013
    39
    Re: TA Test
    Thanks Guys. That's what I thought, but wanted to verify.
    Re: TA Test
    Six gallons of 31.45 % acid will lower the TA by 190 ppm. So, it makes sense that the TA test goes straight to red, which indicates that the TA is zero, or lower.
    The builder is doing an acid startup. They should rebalance the water at the correct time. They should be keeping you informed about what is happening and what to expect.
    To get an idea of how low the TA is, test the fill water and subtract 190 ppm.
    Support the site
    Jan 2013
    39
    Re: TA Test
    The pool builder, while being one of the best in the area has no idea about proper water balance... I asked yesterday, what level of TA, CYA etc they were going to bring the pool up to and his response was...I don't know what the levels are, we just use these bottles of stuff in the dosages recommended by the manufacturer.
    I asked him to not add anything else, and that I would take over from here! My plan is to run a complete test on Wednsday and start brining in it to the BBB recommended levels.
    Jan 2013
    39
    Re: TA Test
    My plan is to bring the CYA up to chlorine pool levels and then use pucks for the remainder of the month until I can fire up the SWG. Then, I will add any remaining CYA needed.
    Sound right?
    Jan 2013
    39
    Re: TA Test
    Oh... I almost forgot to mention this tidbit. I asked him what he used to shock the pool and he responded that it was a type of chlorine that was undetectable by any tests
    FC 12 CC 0
    Re: TA Test
    You want to add both chlorine and CYA slowly and gently during the first three weeks of a fresh plaster startup. Trichlor tablets are ideal for that purpose.
    Jan 2013
    39
    Re: TA Test
    So, just add the trichlor tablets to the skimmer and no extra CYA?
    Any idea how I can figure out how many tabs to add? Maybe one in each (2) skimmer? Should I keep my pump running 24/7 during this time?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: TA Test
    Quote Originally Posted by CivengPE
    What kit are you using for testing?
    Sounds like a good plan. My only comment is to test the CYA while going through this process to make sure CYA does not get too high. Trichlor pucks will cause the CYA to increase, sometimes faster than you think. It is much easier to add CYA than it is to lower it if it gets too high. Use the pool calculator to help determine the dosage, but still test periodically.
    Finally, put the trichlor tabs in an in-line chlorinator (if you have one). If not, place them in a floating chlorinator. Do not place the pucks in the skimmer.
    Jan 2013
    39
    Re: TA Test
    I do not have an inline chlorination, so I will use the floating one. Do I just fill it up with the tablets or is there some method to determine how many to put in it?
    I have the TF100 test kit.
    Sorry for all of the dumb questions. This is our first pool.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: TA Test
    The more tablets, the more chlorine that gets added per time. How much you need depends on your chlorine demand. Figure you'll need at least 2 tablets in the feeder, but you might need 3 or 4. It depends on how much sun their is on the pool and on the pool temperature (especially if there is no sun on the pool) which determines how fast chlorine is getting used up. Why don't you start with a higher number such as 4 pucks and then measure and see how things go -- if the chlorine level is rising, take out a puck, etc.
    Jan 2013
    39
    Re: TA Test
    Quote Originally Posted by chem geek
    Will do. Thanks everyone for the advise!
