Thread: Missing Borates?
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Missing Borates?
    The last time did a full test of chemicals was August. I do chlorine and ph at least once a week and daily during swim season.
    At last check CYA was 40-50 range. Today 60ish. I use a stennar so no new cya added but I attribute the change to the mysterious vanishing dot. I'm never confident in my cya test results. I'll assume it has always been about 55.....?
    TA dropped from 60-70 range to 40.
    Biggest surprise. Borates dropped from 50 to 15? No large water dilution or the cya woud drop?
    Is the cold (55degrees) water effecting readings? Should I add team mule now or wait for warmer water?
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Re: Missing Borates?
    I don't know of any specific problems with the borate test at low water temperatures, but it is plausible that there might be some. I would wait for warmer weather and then do the test again.
    texasdad's Avatar
    Jun 2011
    DFW Metro
    186
    Borates are now at 30 with 82 degree water.
    Jandy 2 speed pump
    So there is indeed a temperature related issue with the borate test. Good to know.
