Results 1 to 11 of 11
Thread: Can't open Leaf canister.
    Fountain Hill, Arizona
    37
    2 weeks ago, I changed the "O" Ring on my Hayward Leaf Canister. The new "O" ring was really hard to put in (it seemed just a very tiny bit oversized - 1/10th oversized), but I lubed it up really good and fit it in.
    I tried opening it up yesterday to clean it and it wouldn't open/unscrew. I tried it on and off for 3 hours and nothing. I took it out to dry today, and tried again... to no avail. I even broke the handle off of it in my efforts.
    Does anybody have any tips on how to get the friggn' top to unscrew or am I S.O.L. and should just go buy a new one?
    Thank you in advance.
    Attached is the same type of canister that I have.
    In-ground 18000 gallons salt water pool, sand filter, 4-5 feet deep, kidney shaped small pebble tech pool with water feature.
    22,545
    Re: Can't unscrew/open Leaf canister.
    A couple of strap wrenches would probably work. You could use a couple of belts and a pliers to improvise.
    37
    Sorry, but I explained it wrong.
    I can get the top part off (the screw top - #1 on the below image), but I can't *PULL* the "LID" off (#2 on the below image).
    I was thinking of soaking the thing in boiling water in a bucket and then trying to pull the top part off or use an x-acto knife to try and cut into the "O" ring.
    Just wondering if anyone here has experienced anything like this and how they solved it.
    Thanks.
    22,545
    Re: Can't open Leaf canister.
    You can try heating it, but it may be better to freeze it.
    What did you use to lube it?
    Where did you get the o-ring?
    37
    Freeze it? Really? Because cold "contracts"?
    I got the O-Ring in an "O-Ring Kit" that I bought when I got a new pool pump a few months back. It came with a whole bunch of O-Rings.
    I lubed it with a tube of lube that I picked up at Leslie's pools here in AZ.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Mine gets stuck when the water is cold. I will usually put the threads on my shoe and use a little leverage to push down on the #2 outlet and the end of the canister. Be careful to not push too hard and crack the canister. When the canister is warmer, it is not as difficult to remove so you might try a heat gun or hair dryer.
    Mark
    37
    Maybe that's what it is. It's been unusually cold here lately and the water has been freezing. I'll try the hair dryer idea and if that doesn't work, I'll toss the thing in the freezer and try that.
    Thanks.
    Quote Originally Posted by mas985
    mas985's Avatar
    Pleasanton, CA
    11,737
    Try to heat the canister but not the lid so there is a temperature difference and the canister expands relative to the lid. Also, it goes without saying but don't get too close and melt the plastic.
    Mark
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Tap it off from the inside, maybe? Use something blunt, like a broom handle, through the hole on the other end.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    May 2011
    Orange County, CA
    696
    I have this same leaf canister, but haven't run into the problems you are having. It is a little bit of work to remove the lid due to the o-ring (which I keep lubed with silicone grease). I remove the screw on retainer (#1) and then gently rock the lid back and forth by grabbing onto exit "pipe" while holding the rest of the unit in my arm. It is much harder to try to pull the lid without rocking it back and forth as described. As for the handle breaking off, I did that once too (well only one side, but still). I repaired this using some slow curing cyanoacrylate glue (super glue). Epoxy should work equally well.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    37
    Sorry it's taken me so long to reply to this (been traveling).
    Thank you everyone for all of your help.
    It turns out that my "O" Ring was not the right size and was A LOT thicker than what it's suppose to be. I got it in a pack of "O" rings that I bought when I got a new pump. I assumed it was for the leaf canister since it looked to be about the right size but I was wrong. Anyways, I had to stick an X-acto knife between the groove and cut all around to pick away at the oversized "O" ring. After continuous cutting, I finally got the top off and went to get a new "O" ring. Comparing the one I used and the new one, it was considerably thicker and just a touch longer. Either way, I probably would have thrown the entire thing out and bought a new one if it hadn't been for this board and your guys help at trying different things.
    Thank you all so much!
    LM
