Thread: Frequency of preventive lamp rubber seal replacement
    I've installed a $150 LED light bulb along with a new lamp gasket/seal two years ago and assume that if the rubber gasket leaks and wets the electronics in the bulb, the bulb is lost.
    I've only had a pool 3 years so don't know what life expectancy to expect from the seal. How often would you replace the $10 rubber seal ?
    thanks
    19'500 gallons in-ground pool and SPA, painted white over black plaster, 1hp Sta-Rite with A.O. Smith B2982 2-speed motor, 136 sqft cartridge filter, currently overhauling a 400'000 BTU Teledyne Lars Mark V heater. Converted to 12v LED party lights. 20-mule team borax saved me from algae depression. San Diego CA
    Re: Frequency of preventive lamp rubber seal replacement
    I wouldn't mess with it if it's fine. Usually only needs replaced when you break the seal.
