Thread: Took The Borate Plunge - But, May Need Help
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    I finally took the borate plunge. I used TFP's guidelines on adding 20MTB and acid. Using TFP's recommended Lamotte test strips, my borate tested at 50. I was shooting for 40...not sure how that happened. Prior to borates I was adding acid every other day to keep PH around 7.4. I was adding 8-12 ounces of MA every other day. Using TFP's recommendations, I'm now using 7.5 as the standard for my pool type. My spa to pool water feature runs strong (est. 3/4 open) for 8 hours a day. Using the smart phone PC recommendation, I'm adding MA every other day (25 ounces) to reduce PH 7.8 to 7.5 with borates at 50 and TA at 75. Seems like I've doubled my acid use since adding borates. According to TFP, TA can run 60-80, so I picked 70-75 as a midpoint. Should I drop my TA to 70 or lower to reduce MA consumption? Any other suggestions?
    11,600 gallon plaster salt pool & spa, IC20 SWG, IntelliPH, cartridge filter, 2.7HP IntelliFlo Variable Speed Pump, Gas Heater, Easy Touch System w/remote, 8 roof mounted solar panels
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Took The Borate Plunge - But, May Need Help
    I have lowered my TA and it has helped.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Lower TA to around 50 and see how that does.
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    o.k. guys...sounds good. As always, very appreciative of the quick response and solid direction. I'm dropping TA this week. Will let you know about the changes in PH consumption/spikes.
    bxcrwlly's Avatar
    Dec 2012
    Central Florida
    120
    So I've been running TA at 50 for a few weeks. Acid consumption to maintain PH at 7.5 continues to be about 23 ounces every other day. Should I raise my TA back to the "normal" range around 70 or leave at 50? Appreciate your suggestions and comments as to whether you think that my acid use is also in the normal range. Borates still holding at 50. Pool temp has been cool between 69-73.
    Maintaining the PH down near 7.5 is not helping. PH increases are larger when the PH is lower and when the TA is higher. You tried lowering TA, so the next thing to try is to maintain PH around 7.7 to 7.8 instead of taking it down to 7.5.
    Since you have borates in the water, there is no harm in leaving the TA where it is.
