Thread: Is it safe to drain pool water that is under ice?
    Aug 2011
    Toronto
    8
    We've had a lot of snow/snow melt and rain over this winter and I haven't been checking the water level as diligently as I should have. Now the water level is about 1.5 inches below the liner lock. If we have another dumping of snow it may reach the deck.
    It being winter, the top is frozen. We have a mesh safety cover and due to snow accumulation most of it in currently embedded in about 2 inches of ice.
    I want to do something about this but I'm not sure what. If smash a hole in the ice to be able to drain a few inches of the water below the ice will this cause problems with the safety cover? It will be the only thing supporting the ice at that point. Also, the ice in the pool itself will likely collapse. Potential for damaging the liner?
    We do have some above freezing temps coming in next week, but only for a couple days but may be enough to soften the ice. Would it be best to do any draining then?
    Do I just leave it and pray I don't get any more accumulation?
    Tampa, FL - 13,500 gallon in-ground concrete pool, standard cartridge filter
    Re: Is it safe to drain pool water that is under ice?
    There isn't anything you can do until it warms up. Draining water will probably damage the safety cover and also risks pool surface damage from the weight of the ice.
    Aug 2011
    Toronto
    8
    Got it. I suppose I wait for any opportunity when the ice is not frozen but mushy.
