Thread: Intelichlor IC-40 question
    Feb 2011
    La Quinta, CA
    21
    I have an IC-40 model chlorine generator that is 8 months old. When the water temp is below 52 degrees the generator stops producing chlorine, that is a default setting. Recommended water salt level is 3400 ppm. There is a red light on the unit that is "on" and says "low salt" which I know is not true because I have had the water tested twice at my local pool store and both times it came in at 3400 ppm. When the red light is "on" no chlorine is produced. I called a tech guy at Pentair (who makes the unit) and told him. He asked what the current water temp was and I told him 59 degrees...he says that is the reason the light is on and that water temp in conjuction with air temp (which locally has been in the high 60s) is still too low for the unit to be making chlorine. He says that is "no problem" because at that water temp, 59 degres, you don't need chlorine as it is too cold for bad stuff to start growing in the water. According to him when the water and air temps increase the unit will start making chlorine again. Water flow is fine, cell is clean, filter basket and the big metal filter are clean. Anybody care to comment about this?
    Re: Intelichlor IC-40 question
    That sounds likely correct, though there isn't any easy way to be sure until the water warms up. Cold water can interfere with salt level measurement sometimes. I'd manually add a little chlorine now and then until the SWG starts running again (one way or another).
    Feb 2011
    La Quinta, CA
    21
    Thanks Jason....that is just what I have done.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    If you have a pool/spa combination, and If your cell is on the main line, you can check the unit by warming up your spa to about 70 degrees. The salt light should go green, and the cell light should come on, if set to 100%. Of course you won't want to leave it at that setting, you are just checking for operation.
    Factory Warranty Station for:
    Feb 2011
    La Quinta, CA
    21
    Thanks Pool Clown....water temp today was 64 degrees....air temp 79 degrees. I'll fire up the spa to 70 and see if the red light goes out and the IC 40 starts producing chlorine. About what temp does the algae and junk start to multiply???
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    If you heat the spa for a couple of hours to test, i think you will be ok.
