Thread: Variable speed pump and mechanical timer
    i'm planning to buy INTELLIFLO VS 3050. my old pump - 3/4 Hp Pentair WhisperFlo is dying so i need to do it quick not so long time ago i got Jandy AquaPure Chlorine Generator and i connected to a timer - Intermatic T104. that was easy - the same wiring like pump - run together. now my question is - can i use the same wiring to my new pump like to the old one? i don't want spend another few hundredths $ for new electric timer. you said "Most variable speed pumps are designed to be started and stopped by a mechanical timer" - but the MOST - what about INTELLIFLO VS 3050?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Variable speed pump and mechanical timer
    Why not just replace the motor or get a 2 speed? Save some money and spend it on pool toys.
    i'm not saying not - my goal is:
    1. quiet pump!!! - current one is louder than grass mover
    2. save $$$ on electric bills
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by qubas
    A two speed is both quiet and saves $$$ and in most cases it will have a lower lifetime cost than a VS.
    But if you are going to go with a VS, I would get a VS 011018 instead of a 3050. The 18 has a built in timer and costs about the same as a 3050.
    http://www.amazon.com/Pentair-011013-In ... ds=VS-3050
    http://www.amazon.com/Pentair-IntelliFl ... rds=011018
    Mark
