Thread: Recommended Settings
    Feb 2013
    Phuket, Thailand
    8
    In the recommended Pool Settings the numbers are there for Plaster, Vinyl, and Fiberglass pools. I will have a concrete pool 100% covered with tile. Would I be OK to use the Plaster Pool numbers or would you tweak any of those for my setup?
    Plaster with SWG
    FC 3-5
    pH 7.5-7.8
    TA 60-80
    CH 250-350
    CYA 70-80
    Pool not built yet: 15K gal, IG Concrete/Tile, Perimeter Edge, Balance Tank, Diamond Kleen Filter, SWG, spec'd so far.
    Re: Recommended Settings
    You should use the plaster numbers. Most grout behaves a lot like plaster.
