Thread: Cleaner pump overheating
    Drew80's Avatar
    Feb 2013
    Austin, TX
    106
    My Polaris pump has suddenly stopped working. I can get it to turn on, but it's not making nearly as much noise as it normally does so I assume it's not spinning as quickly. It turns off after about 30 seconds and is really hot to the touch. I assume it's tripping a thermal cutoff switch.
    I took the cover off to make sure the impeller wasn't blocked by anything, but that's as far as I've gone. Any help with how to diagnose would be greatly appreciated.
    7,500 gallon gunite pool. 1,100 gallon spillover spa. Prologic 8. T-Cell 15 SWG. Hayward 350k BTU heater. Hayward cartridge filter. 2 HP Tristar pump. AquaConnect. TF100
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Cleaner pump overheating
    Sounds like bad bearings. If you spin the shaft by hand, does it spin easily and smoothly? You can either replace the motor or try and replace just the bearings if you can find them.
    Mark
    Drew80's Avatar
    Feb 2013
    Austin, TX
    106
    It turned just fine when I took the cover off. When I've had bearing issues with other equipment, I can usually tell from the noise. The pump isn't making any noise at all, and it was making a lot of it prior to this problem.
    mas985's Avatar
    Pleasanton, CA
    11,741
    The motor is overheating because of some type of additional load. Most of the time it is a bearing causing the issue. However, there are other things that could cause the problem but it would need to add load to the motor such as an impeller interference but you would see that if you too apart the wet end. Another possibility is a winding short a but I wouldn't expect the motor to spin up if that was a problem. Finally, if the shaft seal was damaged in anyway, that could also cause a problem.
    Mark
    Drew80's Avatar
    Feb 2013
    Austin, TX
    106
    Thanks! Appreciate the help.
