Results 1 to 16 of 16
Thread: How often do you run your pump?
    Jun 2007
    North Carolina
    82
    Just curious. We've had ours running 24/7 for almost a week now. Those of you that DON'T run it 24/7, can you please state whether you run it during the day or night? Thanks!
    27' ABG
    Sand Filter
    Yes, both! I run my pump for three hours at night, and five hours during the day. Those will both increase a bit when the water warms up some more.
    Aug 2007
    Northern Kentucky
    20
    I turn mine off when I go to bed and turn it back on when I get up in the morning.
    27 ft. round AG pool with 54" walls, 18,065 gallons, 22inch Sparco sand filter with 2.0 HP 2 speed pump
    Richardson, TX
    287
    during the day when I'm hoping it heats up fast (like now) I only run it during the day and both when it's nice and warm. It depends much more on pool water temp for me than anything else.
    When the pool water gets too warm (happens in Texas anyway) we run it at night with a polaris 'waterfall' to cool the water, helps cool it off a little.
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    CRG_80cc's Avatar
    Jul 2007
    Nor-Cal
    81
    I run mine for 2.5 hours during the day and then 30 mins in the evening just so the water isn't sitting for 18 hours.
    For you guys who run 12+ hours, what's your electricity bill per month??
    30K gal. IG Free form
    Cartridge Filter, Solar and Gas Heater
    Using BBB
    Guest
    Quote Originally Posted by CRG_80cc
    i run 24/7. last summer when we had all 4 ac units cranked at 70. fans, tvs' cooking, hot water, computers, dryer, dishwashers, fridge, lights at night was 650 a month, but thats only in the dead of summer so july through september, rest of the year is an average 400 then when we shut the pool of we go to 325.
    30,419
    Hijack:
    Vince whatever happened to your cloudy, CYA-laden pool? Did it clear up?
    Butterfly's Avatar
    South Carolina
    10,045
    Hijack:
    Dave! (that's for hijacking) J/K........yea, RT, what happened? We need the 'rest of the story'. But, let's do it in your thread!
    Edit: (forgot to respond to the question ) We run our pool 3 to 4 hrs in the AM and 3 to 4 hrs in the PM. But, no night time running.
    You're done SLAMing when:
    Aug 2007
    Austin, TX
    341
    After doing energy audits, I moved our pool pump run time from 16 hours to 10 hours. We also reduced the run time also on the pressure side Legend cleaner pump to run 4 hours from 16 hours. The 16 hours run time (without any home AC units running) ran us around $300 per month. We finally turned on the AC units last night, so I am waiting to see what the bill will be next month.
    I am going to test for 30 days running the pool pump from Noon until 8pm and 10pm until Midnight. The Legend cleaner will run 2 hours in the morning and the 10pm – midnight shift.
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Guest
    8 hours a day in summer, 6 hours a day in winter. I run in two blocks.....In summer 5/3 and in winter 4/2 both midday and evening. These are the times I am most likely to use the pool.
    Mars HP pressure cleaner runs about 2 hours a day.
    Water features come on for 15 minutes a day (otherwise I might not run them for a while and the water in them could turn green!)
    Automation system takes care of it all so I don't have to worry about it.
    mas985's Avatar
    Pleasanton, CA
    11,737
    2 hrs/day in winter and sometimes off
    4 hrs/day in spring & fall
    6-8 hrs/day in summer
    My turnover is about 4 hours without solar and 5 hours with solar so I have never gone much above 2 turnovers per day.
    I also have automation so it is pretty easy to set and forget.
    Mark
    I run my pump 24/7. We open mid April/early May and close Oct. I have pop up cleaning heads in the pool and I like a clean pool. I only have to vacume on occasion, maybe once every 2 weeks with the cleaning system running. Been doing this for 5 years now and don't really notice a difference in the electric bill. Keep the house at 70 in summer and 72-73 in winter. Keep the pool heated anywhere from 82-86 with the heat pump.
    26,000 gal liner IG pool
    Doughboy with concrete construction
    Full sun most of the day
    1.5 hp pump system
    200lb sand filter
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I usually run mine from 5am - 9am, then from 5pm - 9pm. It's on a timer, so I just make sure when I get up for work and come home from work that the skimmer basket didn't get knocked askew during the stop/start of the pump, check the skimmer basket for debris, etc.
    I used to run mine 24/7 because "the pool store said to". After the first year, I thought that was kind of excessive, so started looking online for pool forums, which led me to here.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2008
    Central VA
    328
    Hey Rollin Thunder, I think you told me a few weeks ago I was in the wrong part of VA cause your water was warmer than mine, but now I can turn it around cause your electric is so high one of the few advantages of living in the sticks! ha
    Anyway, I was running 24/7 with Baquacil and still lost that battle to pink slime (hence my membership and incessant questioning on this forum while switching to BBB and then SWG). With that 24/7 last summer, and using my AquaCal heat pump (w/solar cover) to warm up the water at the beginning/end of season, my bill shot from around normally 200 or less to about twice that.
    This year, I've dropped to running the pump 9am-9pm, but I think I'll follow JasonLion and Waterbear's lead and try something like a 5/3 split (or maybe 7/3 or 6/4 if the kids are in the pool all day)...I have a timer for the main pump, but I'll have to fit the Legend Vac into the schedule during the ON times.
    BTW - Sabot, not sure why you'd have to run your Legend more than maybe 2 hours/day? I used to run mine 3 or 4 (or more) hours per day, but now I'm down to maybe 2 or so...just a thought, you may want to try that, since that booster pump is probably using alot of energy also.
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Hmmm....this has been a question for me as well. I have been running it 24/7 since it was finished at the beginning of April. My bill this past month doubled is usage from last year! But, with all the gunk in the air, especially now at least, if you're only running your pump a few hours a day...doesn't your pool get funky??? Just curious............
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    You need to be running "enough" water through the filter to keep the pool clean. If you have a reasonably large pump that almost always gets done in less than 24 hours a day. A relatively small pump attached to a relatively large pool may need to run 24 hours a day. Often two speed pumps run on low speed need to be run 24 hours a day, because low speed corresponds to a very small pump.
