Results 1 to 8 of 8
Thread: Does any body know what type tanker is needed to store chlor
    I an thinking of purchasing a full tanker at a time. I have a few questions:
    1. Does anybody the type of tanker that is needed to store pool chlorine?
    2. Does it have to be inground and can it be above-ground?
    3. Do I need treated cement incase of spillage?
    4. Also the type of permits required by the fire or health department ?
    28,000 gal inground plaster pool & spa w/ 9' deep end & diving board
    Aqualink RS6 w/Pentair Intelliflo VS
    2 ea. Whisperflo WFE 2 hp - spa booster pump & water feature pump
    SWG - Goldline Aquarite w/ Hayward T-15; Heater - Sta-Rite - MaxETherm
    Filter - Pentair CCP 420; In floor cleaning system; TF 100 Test Kit
    22,550
    Re: Does any body know what type tanker is needed to store c
    Are you talking about liquid chlorine or gas, or sodium hypochlorite (bleach)? There's a big difference in the rules for chlorine and bleach.
    How large a tank are you talking about?
    The EPA is gonna be very interested too.
    Liquid chlorine. There is a small shop that has a two tanks of 20,000 gals. They do there own filling.
    22,550
    Those have to be pressure vessels to store liquid chlorine. You're also going to have to have proper handling and safety equipment to be able to offload into the tank. Your best bet is to look at the other store's setup and match it.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by aquascapepools1
    Remember that liquid chlorine degrades with time and temperature especially at higher concentrations. How much do you plan to store and what is the concentration?
    Mark
    22,550
    I think I have a misunderstanding.
    When I say liquid chlorine I'm talking about chlorine gas that's pressurized so that it can be transported and stored. From that you can recover chlorine gas into cylinders.
    Actually liquid chlorine doesn't degrade, sodium hypochlorite does.
    mas985's Avatar
    Pleasanton, CA
    11,737
    While it is true that compressed chlorine gas is liquid, it has been my impression that most of the time folks on this forum think of "liquid chlorine" as bleach and use the terms interchangeably. But the question really should be to the OP.
    Liquid chlorine as in Bleach or compressed gas?
    From Pool School:
    1. Liquid chlorine - Household bleach and liquid pool chlorine are the two common sources. They are identical in every aspect except strength, household bleach is typically 6% and pool chlorine is usually around 12%.
    Mark
    Jan 2013
    League City, Texas (South of Houston)
    39
    That's a lot of chlorine!
    15.7K, IG Sunstone Pearl, 2 - Skimmers, 6-Returns, 2HP Jandy Stealth Pump, 580 SF Cartridge Filter, Jandy Aquapure 1400 SWG, Polaris 280, Jandy Aqualink PDA, Del Ozone EC-2, 10' Diameter Sunken Swim Up Bar With Palapa (built in Kegerator set at 27o), 2 - Jandy LED Lights, Weeping wall with 5 returns, Bubbler in Tanning Ledge
