Thread: 2 speed wiring question
    Apr 2012
    151
    While I am good (enough) with electricity, I have a question about a retrofit.
    If I wire a DPST timer/switch on the common leg of a 220v 2 speed motor, will it still shut the pump off and turn it on?
    If you had to wire a new application 2 speed in (timed on and off) and a polaris booster pump (this needs to be timed too - and only on when pump is on "high"), how would you do it.
    Automation above intermatic mechanical timers is OUT. No Goldine or the like systems.
    LET IT FLY!
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Re: 2 speed wiring question
    Quote Originally Posted by msumoose
    Yes. You really ought to wire both hot legs to the switch before the speed selector if possible, that is much safer.
    You can use a standard timer to do this. Power the timer used to control the polaris from an always hot wire, but run power to the timer switch (which goes to the polaris) from the hot output of the two speed controller. This has the disadvantage of powering both pumps on one breaker.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Intermatic makes a two speed timer:
    http://www.amazon.com/Intermatic-T10604 ... c+t106+104
    You can wire the booster to either the high speed, low speed, or the on/off depending on how you want it to operate.
    Mark
    Apr 2012
    151
    If you had to wire a new application 2 speed in (timed on and off) and a polaris booster pump (this needs to be timed too - and only on when pump is on "high"), how would you do it. You can use a standard timer to do this. Power the timer used to control the polaris from an always hot wire, but run power to the timer switch (which goes to the polaris) from the hot output of the two speed controller. This has the disadvantage of powering both pumps on one breaker.
    This is what I had sketched up...but was wondering about the motor itself..thanks.
    So the speed selector switch should be parallel to the timer (after the breaker?), and using the breaker (not the main panel breaker - a breakout box) as a switch for ALL power?
    Apr 2012
    151
    Quote Originally Posted by mas985
    Yes, but that won't fit this install. I originally was going down that road...
    I was thinking breaker -- DPST master power switch -- switch or timer to control speed -- motor
