Results 1 to 20 of 20
Thread: TF100 first test, clear/green tint water
    The water is clear but has a green tint to it, I just got my new test get and want to get started getting ready for spring. I will do the overnight test for FC tonight.
    FC 4.5
    CC 0
    PH 7.5
    TA 30-40
    CH 110
    CYA 20
    Water temp 47 degrees
    15k freeform shotcrete sport pool 3.5-5-4, hayward swimclear c4030, 1.5hp hayward Northstar pump, polaris 280 with hayward booster, hayward turbo cell swg
    22,544
    Re: TF100 first test, clear/green tint water
    Clear green indicates metals in the water. Do you have a history of metals?
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    The pool is only about a year old, have not had any problems with metal. The chlorine got very low, down to almost nothing about a month ago, after being neglected throughout December. I had made the mistake of thinking it was too cold to worry about.
    Usually clear transparent green water is metals, but it is possible for it to be algae.
    What should I do to try to clear it up??
    38,267
    Start by raising the FC up to shock level and performing the OCLT. If you fail, that confirms the presence of something organic in the water and then you should continue the shock process.
    So shocking would fix the metal as well? I will do the oclt tonight and report back.
    38,267
    No. I was only suggesting the OCLT to help determine if the green is organic or not. If you have a large FC loss overnight, that points to algae and not metal and then you would perform the shock process. If you do not have a large FC loss, that reduces the odds of the green being due to algae and then would point you to dealing with the metals ... By using a sequestrant.
    Last night FC 4.5 this morning it is at 3.5-4 it was almost clear at 3.5 completely clear at 4.
    If it is not some type of algae, where would metal in the pool come from I haven't filled it or added water lately.
    22,544
    You technically passed the OCLT, but you should raise it to shock level FC and run it again. Just to be sure.
    You didn't list CC's in your OCLT and that's part of it.
    Do you have a lot of trees around the pool that's dropped leaves in it?
    With the water temp at 47F I suspect your swg isn't making chlorine so how are you keeping the FC up?
    Yes lots of trees, the swg is not generating, I use a floater with chlorine pucks.
    22,544
    Some chlorine tablets have copper in them. Look and see if it's a multi tablet (i.e. 3-in-1, 4-in-1, etc.). Also, look and see if copper is listed as an ingredient.
    You are awesome, will check it out.
    The tabs say active ingredient: trichloro-s-triazinetrione
    38,267
    What brand? What else is listed on the container?
    Leslies, 3 inch jumbo tabs.
    Trichloroisocyanuric acid, dry
    38,267
    OK. Those do not have the copper in them.
    As Bama suggested, raise your FC up to ~10ppm today and perform the OCLT again.
    Liquid bleach? Any brand in particular? I'll go buy some right now and get this going.
    38,267
    Either Bleach or liquid chlorine ... same stuff the LC from pool stores is stronger 10-12%, but the plain old 6% or 8.25% bleach is usually cheaper per ppm of FC.
    Just make sure there is no additive in the bleach ... like smells or splash-free, etc
  20. Back To Top    #20
    Bleach added, will test in a few hours
